Knock,knock. Who's there ? 1,000. 1,000 who ?
Results 1 to 14 of 29
    Default Knock,knock. Who's there ? 1,000. 1,000 who ?
    1,000 Horsepower, that's who.
    Tomorrow the 565" will be back on the dyno knocking on the door of 1,000 hp all throttle, no bottle with a single carb.
    Here's the story; one month ago at the river an external oil line came loose somewhere between Hidden Shores and Fishers. The oil pressure never droped below 60 lbs on the way up, but once I came off plane at Fishers the oil pressure droped below normal. Oh shit what's that? Checked the bildge and there must of been 5-6 qtrs of oil in the bildge. Damit... Mother ***** etc, etc.
    I have no one to blame but myself, before I left Hidden Shores I told myself to double check all the oil lines. Checked the filter and both lines at the top of the oil adapter and then a friend came up and started talking to me and I never checked the lines at the oil cooler. That was a very expensive beer my friend gave me . No one to blame but myself though.
    Anyway she took out the # 5 main and she required a little bit of surgery. All done and back together. Other than the $$$ I only lost one river trip. The schedule has been a bitch over the last 6 weeks.
    So this is what I'm looking for tomorrow: The old (last yrs combo) made 765 lbs ft. @ 6,000 and 935 hp at 7,000. I had a few issues on the dyno and didn't get all that was there, but walked away pleased knowing that she had more in her. I hope to extract some of that tomorrow.
    My C&S carb was sent back to Kansas and wet flowed for two hours, they say it will be worth 20-30 Hp over the 1050. It wet flows around 1,180 cfm 1,300 dry. It still might be 150 cfm short. But in anycase I doubt that I'll be pulling 1.4 in vac at 7,000 ( I'll call it 15 hp)
    Mobil one 15-50 will be worth a minimum of 10 hp ( last three times on the dyno Mobil one picked up 12-15 hp with this engine) I'll call it 10 hp.
    Super Sucker 2" carb spacer vs 1" open. Lot's of experience with these. I'll call it 10 hp
    That put's me at 970 hp. Dan Crower made a few adjustments that we think might be worth another 10 HP So that puts me at 980 at 7,000. For an increase of 45 HP. Assuming I'm 90% correct that would be a 40 Hp increase for 975 HP. That's the target 975 +/- 5 hp.
    If she can hit 975 HP on VP C-12 when we are done we'll drain the fuel cell and drop in 2 gallons of VP Oxygenated race fuel worth between 4-6% over C-12 up jet 3-4 jet sizes, drop the timing 2* and let her rip. 5% of 975 is 48 HP. 975 + 48 = 1,023 HP.
    So, if my math is correct and my dream wheel calculator is spot on I really only need 965 hp at 7,000 on C-12 if the MR Oxygenated fuel can produce a 4% power gain = 38 hp.
    965 + 38 = 1,003 hp.
    So tomorrow I hope to have a 975 HP sheet and a 1,003-1,020 HP sheet.
    I any case I'll be knocking on the door of 1,000 HP, I hope he's home.
    Wish me luck.
    Engine spec's: http://www.performanceboats.com//showthread.php?t=1874
    Sleeper CP
    Big Inch Ford Lover
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    It sounds like you might of put a little thought into this goal of yours Good luck Jon.
    El Cajon, CA.
    That's a lot of HP for a river boat, good luck.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    man i thought i was a ford nut id like to see this motor run
    coolio please tell me you're squeezing it too after all that nitrous on the dyno talk
    Good luck John, although luck has little to do with it. I'll be watching this closely.
    How much you getting that Oxygenated fuel for? I know in quad land that VP u4.2 is gettin pretty expensive....
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    That is a shit load of power for a lake river boat.
    Good luck on the dyno.
    Steel will tell you how much I think about dyno pulls........
    But in all honesty I dig seeing guys really get into the nuts & bolts of any subject. You obviously have thoroughly thought this deal out.
    Not this time. Just getting on and off but no bottle.
    Quote Originally Posted by 76Miller View Post
    Just a tad bit of thought It won't be on pump gas, but Im okay with that. If it makes less that 965 I'll be disappointed. 975 hp +/- 5 seems a realistic goal, but if I take the high numbers from all the "guest"imates it could spit out 990 HP on the C-12, but I highly doubt that it will be that much of an over-achiever.
    Sleeper CP
    Combination,combination,combination.
    I had to resit Dan ( www.crowerpower.com ) wanting to put a bigger "stick" in it. The only thing that stopped him was the piston /valve clearance.
    He really wanted to put a cam in it that would change the trq. #'s from 765 at 6,000,874 hp (702 at 7,000, 935 hp ) to 780 ft. lbs at 6,400 (950 hp) and 720 at 7,200 ( 987 hp). With the bigger carb and other changes we would be looking at approx 1,030 hp at 7,200. But I didn't like the ideal of the additional duration either. I like the fact that this engine idles at 800 with a lope and is smooth at 1,000 (she purrs). It's a "ski" boat after all
    Sleeper CP
    Well????
    Senior Member VAMI's Avatar
    srq,florida
    What size impellor you gonna run if it gets max power at 7200?Almost need a C cut.
    srq,florida
    How heavy is that ski boat?
    sounds good i am doing some pulls tomorrow too
