Carbon Build up From Race Fuel - Heads Valve Seats
Results 1 to 14 of 24
    149 BGJ-Willis Power 540 willis's Avatar
    Gardena, CA
    Default Carbon Build up From Race Fuel - Heads Valve Seats
    July 21, 2008
    Hello People
    Just wanted to know if anybody has problems running 120 Oct fuels with the heads?
    In particular the build up carbon on the valve seats causing leak down problems because the valves will not seat?
    Sunoco, VP, F & L Distributors - ST 118, Turco.
    Cantard 71hallett's Avatar
    snow bank
    I have seen this in a to rich situation. Carbon on the pistons aswell?
    Default temp?
    oil temp ? Sounds too cold or too rich or both.
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    Willis,
    Know your running a PSI Roots ... it would help to know your static compression ratio and the boost your putting to the motor ... assuming something like static 8.5 to 9.0 and your boosting something like above 20 + percent ... under 30, 120 Octane seems alot ... octane stilts ignition ... perhaps your running too high an Octane ... Have you run VP C16 (117) consistently enough to get a 'read' on how it does?
    Jak
    Gardena, CA
    Jak,
    What I did was change fuels from C-16 to Turco stuff and its 120 Oct.
    Ran one race and checked the leakdown.
    The numbers coming back indicated that there was something wrong in the heads.
    I took the engine apart and the build up of carbon looked like a sponge on the valve seat and where it seals.
    There was only one change and it was the fuel. VP didnot leave that kind of carbon in the chambers.
    That race was a test run on the new fuel. The blower psi was 31lbs and static is 8 : 1.
    willis
    Rural Missouri
    Willis,
    Can't really be specific without actually seeing (being there) what you have going on ... can only give you some 'maybe's' .....
    Talked about it a bit with Mike and:
    C 16 has a spec. gravity of 0.735 ... Assume you used Torco 118 (MON 120) 'Orange' ... it has a spec. grgaity of 0.710 ....... this means to stay @ the same mixture of a/f you would have had to increase the amount of Torco in the cylinders by minimually 3.4 % ... if you did, fine ... if not, you were leaner ... How did the plugs look? If they looked on the normal to lean side, then you were lean and what your seeing on the valve seats may in fact not be carbon, but, aluminium (piston material/head) due to being lean and higher heat... if the plugs looked 'sooty'/rich then could well be carbon ..... ??? Can't tell 'from here'.
    Not seeing things first hand, I won't venture on the solution of using the Torco (things like taking timing out, increasing tha amount of fuel, etc.) ... what I, personally would do is say 'screw' the Torco and go back to the C 16 ... If it ain't broken, don't try and 'fix' it ... just me.
    Sorry, can't be of more help without being there.
    Jak
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    the last race i hit the ground when that boat was running it shoot the ducky of ming for the fast boats to run
    Gardena, CA
    Jak.
    I started cleaning up the short block for reassembly of the heads, and notice that there is a large residue of black soot.
    71 Hallet was correct it was exstremly rich.
    Just didn’t want to have another set of piston half melted.
    78 Cole, you are correct for the June Race, now lets see how you do with my boat.
    See Ya out there
    snow bank
    Start pullin a little fuel bit by bit and watch that thing come alive. That rich almost seems to shove fuel deep in the plug making it load down like your at the end of your power. Baby steps are key. What carb are you using?
    snow bank
    Also be carefull running the orange torco, it will start to close up your jets if it sits any amount of time.
    Gardena, CA
    No Carbs - injection - old school Enderle and psi blower
    We
    made sure that that the enginge was fat.
    With all the other issues that were found, we did not burn the thing up.
    That ST 120 Stuff distributed from F & L fuels of Long Beach, CA is what we are going to try.
    It looks just like the Turco 118 and has the same properties.
    Willis
    Golden Shores,AZ
    hey wiilis if i had the money i would of bought blade runner and had a good time with all the blown gas jets
    Gardena, CA
    Quote Originally Posted by 78CoLeBBF View Post
    Jeremy,
    You should stick to side line observations.
    It's a better suit for you.
    Senior Member bp298's Avatar
    LHC
    that's a pretty big jump in s/g, as well as a lot of other fuel specs that are not easy to obtain. why change from what you were running?
    if i were you (of course i'm not), i'd haul the entire fuel system to a certain shop in havasu, and get it all tuned up for the fuel you intend to run. and if ya need directions, i'll lead ya there and take you in the front door
