Guess my Horsepower BBC
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 121
    Jan 2013
    Magic Mountain CA
    Default Guess my Horsepower BBC
    I'm not going to Dyno this anytime soon and was wondering if anyone here has a similar build or the experience to give me their opinion.
    BBC 468
    4 Bolt Main
    Forged Crank
    GM heavy Duty 7/16 Rods
    Clevite Main & Rod Bearings. MS829H – CB743HN
    Hamburgers 10 qt Oil Pan with Mellings HV Pump
    JE Flat Top Pistons & Rings 8.1 Compression
    (Bore & Ring gap spec’s to Bob Teague’s Recommendation) (Machine work at Adam’s Metalizing in Lancaster)
    Comp Cam 11-568-4 Nitrous HP Lift 284/305, Intake 575, Exhaust 595, 113 lobe separation.
    Comp Valve Springs 924-16 (2800rpm – 6800rpm)
    Comp Pro Magnum Lifters Hydraulic Flat Tappet
    Iron Square Port Heads with Ports cleaned up
    Teague 1.7 Roller Rockers
    Manley Push Rods
    Edlebrock Victor Jr Intake Port Matched
    M3 Pro Charger with Intercooler pushing 9 psi.
    QFT blow through carb 750 cfm. (Carb good to 1000hp per QFT)(Jetting 85 & 95)
    Fuel system designed for this application.
    MSD Ignition
    Basset Headers
    I have a thread going on in jet boat section about next impeller. Runs 86mph on GPS at 5200 rpm.
    Thanks!
ID:	277258   Click image for larger version.
    Any flow numbers?
    IMO you have way too much ex lobe on this deal. Lot of power going out the ex pipe.
    Jan 2012
    lake Charles, Louisiana
    I'll guess 700-725
    Jan 2013
    Magic Mountain CA
    Any flow numbers?
    All I have is the parts list. Cam decision was made by Comp cams techs, I called and gave them this info and they suggested what I have. Engine runs really strong.
    WV
    Quote Originally Posted by 74Bonneville View Post
    BBC 468
    4 Bolt Main
    Forged Crank
    Manley Push Rods
    MSD Ignition
    Basset Headers
    Thanks!
    865Hp 785Tq
    BBC 468
    4 Bolt Main
    Forged Crank
    Manley Push Rods
    MSD Ignition
    Basset Headers
    Thanks!
    If you know the impeller size, shouldn't you be able to find a chart that gives you horsepower based on RPM?
    Jan 2013
    Magic Mountain CA
    I would think so, but how would it be accurate with so many different types of boats? I've been speaking with Duane at HTP and he does have charts that he has been referring too. We're going with an educated guess of 750hp. New impeller on the way.
    I like JSspeeddemon's guess, I was thinking 800 or so before I started speaking with those who know way more than I do.
    If I had the funds a set of AFR heads, matching intake & a bigger cam would let this thing breath, someday
    Thanks again for everyone's help, I like this site
    What impeller are you running and what rpm are you seeing?
    Senior Member MBMoseBilt's Avatar
    500 HP at best.
    Just kidding. Gm crank and rods. 700 HP.
    Would have no idea without knowing your flow rates and compressor size.
    Jan 2013
    Magic Mountain CA
    Heritage aluminum AA - 5200rpm - GPS 86mph - Yes I know aluminum not good for this, but didn't want to invest in high end impeller until I ran it a few times
    AA @ 5200 puts you right about 550-560hp at the impeller, in that weather, on that day.
    Senior Member bp298's Avatar
    LHC
    what's your goal with this thing? what do you use it for? you said you're getting another impeller, what is it?
    as a wild ass guess, i'd say 600-650 absorbed. at that rpm. you're going with a different impeller, but without a dyno sheet there's no real way to know how much performance improvement you'll see, whether it's larger or smaller. 600-650 at 5200 is a pretty good number. and if an impeller were to allow rpm to run higher, performance may improve IF the engine is making more hp at higher rpm. but without a curve to tell you that, it's just a guess.
    My guess is apx 550 hp. But I dont know chit.
    Edited to add: That's per Jack Sea's chart. Duane's chart shows ~500hp for an A @ 5200, so that's a pretty good confirmation on the 550-560 for a AA. Corrected power would depend on the weather that day.
