cant figure out how water is getting into the combustion chamber on #3 cylinder-bbc
Results 1 to 14 of 17
    Senior Member badbug3's Avatar
    Default cant figure out how water is getting into the combustion chamber on #3 cylinder-bbc
    My nephews 24 ft htm has a 565 gen v 10-1 motor with edelbrock aluminum victor heads , roller cam, dominator , lightning exhausts, and has been running fine for years. All of a sudden at 5800 rpm it starts to miss a little so he brings it back home and we remove the sparkplugs. # 3 cylinder spit out quite a bit of water when the plug was removed. Turned engine over and more water came out of that hole. Did a leakdown and that hole is 18% leakdown. 1 , 5, and 7 are at 4 % leakdown. Removed intake and gasket is solid stuck with NO evidence or leaking around port. No water in oil. Removed head and it has felpro 1075 mls gaskets. No sign of any leakage around combustion chamber. There are signs of some water spots in cylinder from most likely a getting worse situation to the point of misfire. Cant find any sign of a crack in the cylinder, head . A close inspection of the lightning headers , which are 12 years old, shows no signs of water going thru that header tube. What to do next?
    Quote Originally Posted by badbug3 View Post
    So was the leak in the intake, exhaust or rings?
    If you have the head odd, pour some laquer thinner iso-alcohol in the exhaust port of #3 and see if it leaks out of the exhaust valve.
    cylinder leakage was going past the rings. Intake and exhaust valves seem good. I filled exhaust with brake cleaner about 1/2 inch deep and nothing was leaking around the valve, nor the intake and the same with the rest of the cylinders.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Valve guides go through water. Sometimes they will seep past the guide. Boats will corrode the guide pretty bad because there is no coolant.
    Pressure up the cooling system.
    Also the exhaust header should be suspect.
    QE 439 Twin Turbo
    Placentia, CA
    12 year old Lighting headers is where I would look first, probably a small leak at weld joint.
    steveo143 AKA DiMarco 21 II
    Senior Member dankdave79's Avatar
    Sep 2010
    Yea some how try and pressure test the header
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    I have heard of Gen V blocks leaking around the head studs, bolts with thread sealant may fix it, but u would signs on the head gasket I would think
    Quote Originally Posted by steveo143 View Post
    That would be my guess.
    Keep in mind, the water is not getting in the oil but in the combustion chamber only. The head bolts go into blind holes where there is no water to seep back.
    New Port Richey, FL
    I've seen that happen from exhaust and guides both. Pressure test the exhaust and if OK pressure test the head.
    Correction I have seen water get in the chamber from pin holes in the exhaust port also.
    QE 439 Twin Turbo
    New Port Richey, FL
    That only happens to flat bottoms.
    QE 439 Twin Turbo
    Had a cylinder wall that would only leak under load. Preasure checked the block in the boat with 60psi. No leak. Came back the next morning and a small rust line had formed in the middle of the cyl. wall. Like Magnaflux. I figure the 8-22psi of water during opperation and the piston swingin' on the major thrust face would open it slightly and ingest water. It (the crack) ran somwhat verticle and peeked just below the bottom ring, so it would make a little milkshake. New block for me. Hope this isnt your prob. because it took me weeks to find it.
    Info , you were right about the pinholes. The leak is coming from the water jacket seeping through the pores in the exhaust port on 2 cylinders. Heads are edelbrock victor and i was told today that was a big problem with those castings. why after 12 years do the heads decide to start leaking ???? Its a shame as the heads are show polished and look very nice.
    New Port Richey, FL
    Where is the pat myself on the back smilie?
    QE 439 Twin Turbo
