BBC weak head stud threads...need those special solutions by Pioneer bolt??? GN7?
Results 1 to 14 of 23
    Senior Member A handfull's Avatar
    Default BBC weak head stud threads...need those special solutions by Pioneer bolt??? GN7?
    You guys had a kick ass solution for these on an old thread. Someone bought a bunch of NOS pieces from a bolt supplier...and I need several for a 14-71 alcohol injected 468". Boat runs strong 8 flats...but several studs are giving up at around 50ftlbs...damn.
    I think you..GN7...had good luck with two diffetent brands. Thanks in advance.
    Thanks!!!!
    Quote Originally Posted by A handfull View Post
    Thanks!!!!
    Not sure where you guys come up with this stuff. Somebody was suggesting I knew of some cool breather too. I have never used a VC breather.
    Anyway, not sure what you mean by giving up. You mean the stud is failing? Are you sure you aren't pulling the stud out of the block threads? Never failed a stud in my life, and the inly studs I have ever used are ARPs.
    If you are in fact failing the studs, I would be replacing one or two, I'd be getting rid of them all.
    Thanks!!!!
    If you are pulling studs out of the block then its heli-coil and new stud time!
    okie, lake Texoma
    Its to bad they dont make a blind tapped insert so that once installed the water couldnt get to the stud any longer.
    H8-2-W8
    [email protected] first pass
    Quote Originally Posted by hass828 View Post
    its to bad they dont make a blind tapped insert so that once installed the water couldnt get to the stud any longer.
    you make them
    okie, lake Texoma
    you make them
    I dont like waiting for that much J&B weld to set up.
    H8-2-W8
    Default Yes..block threads are failing. There was an older discussion...Hi quality Heli coils
    There was an older discussion about a Hi Quality Heli Coil repair...I can't find it now...I thought your were involved with that discussion...actually a guy put a nut on the back side to get him by at an event before he got a hold of this special deal...then he never had a problem afterwards...anyway...any recommendations would be great. The head studs are fine...the stock block is just letting go unfortunately. This is an alcohol deal and I do not run water in the block.
    Also...on a side note..SLOW BOYS jet boat blower deal was an interesting discussion...where you suggested that the heads are backing up the flow of the blower...they just plain don't breath enough air...and the boost backs up in the plenum..and power falls off with more boost. Where did he wind up with his new combo?? Anyway...I did see that boat run last year with his old set-up...and it was very impressive...it left very quick and sounded clean. The guy really had it set up nice....I would love to see him drag that boat down to Wheatland this year. Anyhow...thanks for a quality MFG suggestion and maybe a part#.
    Default Found the old discussion. Thanks for the help.
    Here's the old info if anyone needs it:
    Nutsert..Kingsert...Keensert...Bigsert...Pioneer Inc Part#EL-7...and Grainger item#4ZE22...were all recommendations..use red locktite or JB Weld on the stakes so water does not leak.
    EX. 5/8"x11
    INT. 7/16"x14
    The keen serts work well, I think you drill the hole with a 9/16" bit and like GN said you use a 5/8"-11 tap so you dont need a bunch of special stuff. I would JB weld them in so that the threads on the block don't rust any more. I had a 396 block and it had several helicoils and keen serts in it. I finally jb welded in a set of studs and never had another one pull out. I just hate that feeling when torqueing the head bolts and it seems like it is going a little too far before clicking.
    Good Luck,
    Chris
    Iuka, Mississippi 38852
    the pioneer EL-7 has worked well for me at least 15 times. i usually use them if a helicoil has failed. i figure that since the helicoil has the smaller o.d., i use it first. it gives me two shots at the same hole. be very sure to drill and tap straight.
    sorry. I misunderstoof the opening post. I was under the impresion you had a failed cheap stud not a pulled thread in the block.
    the Keensert, Big Serts, and others require a special tap. I am not familiar with the Pioneer product.
    I like these beause they come in 2 wall thickness and you use a standard tap.
    McMaster-Carr
    Unhappy o-ringing block after bigsert repairs
    McMaster-Carr
    I am not running water in block. It is o-ringed, and the repair will run into the o ring. Would you try it without re oringing the bock?
    I am only running 12-14 psi on alcohol.
    I wonder if the oringing will have issues going through the inserts.
    What's your take on it?
ID:	297826   Click image for larger version.
    waterloo
    UH OH...
    I predict this thread is about to take a turn??
    Wags
    Jun 2010
    Go for it Matt you should still clear it
    UH OH...
    Wags
    Not really, I haven't recovered yet from the fact that the oring grooves are that far out from the bores.
