Bbc pistons 1.56 compression height
Results 1 to 7 of 7
    custom member raped southwind's Avatar
    so-cal
    Default Bbc pistons 1.56 compression height
    Found a set of brand new arias large dome pistons sitting on a shelf. 4.280 bore but compression height is 1.56. Only config I see these working in is a tall deck 4in stroke with 6.635 rod! Any one have any ideas before they become ash trays?
    Quote Originally Posted by raped southwind View Post
    send me a PM want you want for them
    Tower Park Resort, Lodi, CA
    Didn't figure you as a smoker.
    That's an odd compression height. A 427 crank with a 6.385 rod only puts you out of the hole a tad with a standard deck block (.025"). A .065 head gasket gives you .040 to the piston. That would be a fun 432" engine with that 1.7 rod ratio, some good heads/cam/induction and spin it.
    so-cal
    That would work. Too bad i already told bob he could buy them. And i have a 427 crank sitting here too. DANG
    If you what to buit a 427 with them that fine with me,
    they work the same with 4.25 crank and a stiock 6.135 rod
    If you don't have to deck the block
    so-cal
    my block has already been decked to 9.780 so id have to find another block. kinda stupid to build a motor around a set of pistons! if i had everything sitting around id do it but since id need rods and a block id rather just stay 4in stroke! or 4.250 with a 6.385 rod . they are yours bob
