cam help 502
Results 1 to 10 of 10
cam help 502
    Nov 2008
    Default cam help 502
    I got a 2006 Gen 6 marine 502 model # 12568778. I have upgraded to imco power flow exhaust and edelbrock air gap performer rpm and msd ignition. 850 demon carb. the motor is in a 20.5' placecraft skier with setback Berkley. I want to put a bigger cam in it to take advantage of the induction and exhaust improvements. Any suggestions or experiance with a upgraded cam. I believe the motor is a 450hp motor stock. Thanks Jason.
    Nechako
    a comp xm284hr would be about your max with stock springs . probably about max for wet pipes as well
    Tower Park Resort, Lodi, CA
    Quote Originally Posted by cc23 View Post
    What rpm does it spin now?
    Do you plan on changing the impeller too?
    New here Beer:30's Avatar
    Bakersfield, CA
    This is mainly geared toward EFI motors, but would work just as well with OK with your Demon. I would go to a single-plane instead of the air-gap intake though.
    Crockett Marine Engines
    Nov 2008
    Thanks guys I don't know what it will spin now as I bought the boat with a hurt motor. Motor had a bad stock head gasket and a chunk of piston broke of in the number 3 hole. Its getting new bearings and rings, piston, valve job etc. I just thought while I was in there, might as well. I don't want to get crazy as this winter I wanna pull it down and do a 540 kit and heads on it.
    Thanks Jason
    Tri-Cities, TN
    Thanks Jason
    If this is your plan then stick a used ZZ502 cam in it for the season. Save the money and build the 540 with the right cam in it this winter.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    That's good advise right there from the guy to go to when you need a new cam for that 540.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Nov 2008
    Thanks anybody got one?
    Nov 2009
    X2 this is straight up Legit advise!
    Competition Products Has A Ton Of Them, Priced Right Too.
