Dual keyway crank/balancer
Results 1 to 8 of 8
    Default Dual keyway crank/balancer
    Do you guys run it? Recommend it for blower apps 15lbs and under?
    Gone
    Sparks, Nevada
    I use a single keyway.....but make it 1/4". Never a problem. If it is a circle boat that also drives off the balancer then I would do 2 ea 1/4" keyways.
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    Quote Originally Posted by Crowldog View Post
    Better safe than sorry, i have dual 1/4" key ways, on a romac blower balancer.
    It's not that i don't care, I just dont give a sh!t!
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Two if it makes you feel better ones enough for a 8 71 pushin 15.
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    If it makes you feel better, it is much cheaper to add a keyway in the crank and balancer now, than it is to replace them if it DOESN'T work.
    Brian
    Quote Originally Posted by wsuwrhr View Post
    If it makes you feel better, it is much cheaper to add a keyway in the crank and balancer than it is to replace them if it DOESN'T work.
    Brian
    You've got a point there bro
    Yes sir.
    Senior Member Sanger Greg's Avatar
    SFV LOS ANGELES
    Default keyways
    I always run dual its cheap insurance.
