idle bypass
Results 1 to 10 of 10
idle bypass
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default idle bypass
    Blown Alky deal what should I be looking for for a idle bypass pressure in the check valve?
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by steele211 View Post
    8 lbs
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Depends alot on the fuel pump, what do u have 80a, 110?
    Dec 2010
    Sapulpa ok
    5-6 psi is a good mid road setting
    Nov 2008
    Kingsburg,CA
    110 pump
    Jan 2012
    lake Charles, Louisiana
    Anywheres from 5-8 normally, have been up to 10 before
    Led
    Led is offline
    Jul 2010
    110 pump
    Piston knows his FUEL stuff, I have a 110 with an 871 on a 540, i have a 6 psi check,
    Jan 2011
    all that check valve does is help it start after it starts the pressure will open the poppet valve and it will be open all the time.
    Nov 2008
    Kingsburg,CA
    Am I wrong in thinking that the pressure in that will change how the motor idles because as the pressure goes up it sends more fuel to the motor before it kicks open. Or because its open as soon as the motor fires any way it won't matter?
    Jan 2011
    it opens as soon as it starts
