enderle mechanical injection
Results 1 to 9 of 9
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    Default enderle mechanical injection
    I was thinkin of converting my blown 461 ci bbc to a hat style mechanical injection and getting rid of the 850 carbs. It runs on gas now and compression is 8.5 to 1 with a 8-71 mooneyham blower. Other than looking bad ass what are some pros and cons and are they easy to tune, and how is driving the boat around with a blown injected setup. thanks
    It's not that i don't care, I just dont give a sh!t!
    Senior Member Morg's Avatar
    Reno, So close to hell you can see Sparks.
    I have ran mine a couple of times with the Enderle.
    Last time out at the lake I took the wife & my 3 year old son out for a cruise.
    The throttle is going to be much more responsive with the Enderle. But with throttle control it works just fine.
    i've gotta compelte enderle birdcatcher system in runnable shape(just pulled it off last month) for sale cheap, 1100 including priming set-up. call me mr spam i need to sale to get mo parts
    here it is on the boat
    Atlantic Beach, FL
    You might consider a hilborn 4 hole hat. More drivability than the 3 hole Enderle, but its still not as friendly as carbs, but accelerate like no tomorrow!
    If you're at the LB races this weekend, check out GN369, Heath Hiebert's boat. He has that setup and it works pretty sweet. He can give you some info on his experiences with it.
    Gone
    Sparks, Nevada
    The carbs are more forgiving to altitude and tuning. Unless you want to really understand how MFI works and willing to tinker and tune a bit...don't go there.
    You have to squirt or prime an injected motor to start. The carbs you don't have to.
    Throttle response is better with the injector. Part throttle operation or crusing can be close to the carbs.....but you have to mess with it to get it.
    To some...that's the fun. To others its a hassle.
    Quote: "Its the hard that makes it great" - Jimmy Dougan
    Senior Member lilrick's Avatar
    Lakewood
    if you're willing to work at it, go for it.
    Members only MAXIMUS's Avatar
    Close by
    I wouldn't run anything but a hat on a blower. 1 on my ski boat & 2 on my race motors...
    Senior Member 500BBC's Avatar
    CIUDAD MEXICO NORTE
    I'm running a bird on my 871 in a 19.
    I'll never go back to carbs. Had the hat setup by Enderle to my specs and only had to adjust the barrel valve four flats. No partial throttle problems and I added another injector with a solenoid and small electric pump to prime it.
    The plumbing was the biggest PIMA, I have the bullet tank that came out of your Rayson and a T tank is much easier to plumb in a cruiser application.
    It's not as sloppy as it looks in that pic though.
