cam feed back on blower mtr
Results 1 to 6 of 6
    Senior Member nasty toys racing's Avatar
    Default cam feed back on blower mtr
    im running a 496 14-71 blower with chiller i need some feed back on this cam,is it right ,will it work,i dont no 4 my aplication,it ran in a 19 daytona,like a cheeta on steriods, herbert cam , lift-.698-int ,700 ex, duration advertised, 304-int ,313 ex, duration @ .050 269-int ,275 ex, valve lash, .025-int ,.025 ex, center line 106, the lobe center,112, heads r eddle brock performer rpm marine heads. any feed back will be great
    Kingman/Golden Vly, Az
    Quote Originally Posted by nasty toys racing View Post
    u need to get ahold of cstraub69 on the boards...he grinds cams for all applications & can help u...i personally think the 14-71 is a little over-kill!!...i'm building a blown 496 & am gonna run a Mega 420 with a chiller & Holley 450cfm carbs...not set on the cam yet, but will prob run 1 that will give me low end torque & mid range power...its going in a '73/76 Kona 18' with Berk jet etc...just my .02 cents
    FastRat
    ptz
    ptz is offline
    so ca
    what did chet say ?
    112 is too tight.
    116 is better.
    Atlantic Beach, FL
    FastRat
    450 carbs? You running a V-6 ?
    Tri-Cities, TN
    Blower cam, no need for advance, huffer will stuff it in there, needs to be 112 straight up. Ebrock heads need more exhaust crutch then what you have there. . .about 14 to 16 degree of split at .050. I'd say present cam is smothering engine because not enough duration to evac exahaust.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    okie, lake Texoma
    Well said.
