Intake / Head question
Results 1 to 14 of 31
    Albuquerque, NM
    Default Intake / Head question
    Ok, so putting together a tall deck motor with heads and a block that came used and from different sides of the earth. Long story short, the intake does not fit. After very quickly looking at the block deck height it seems ok relevant to the pistons, so I am guessing the heads have been angle milled or cut. (Note the intake is a new dart tall deck intake)
    When I set the intake on the block with no gaskets it rests on the front and rear valley ribs. I can push the intake over to one side and can measure just under a 1/4 gap on the other side.
    I then lifted the intake and set some thin cardboard under the front and rear ribs and centered the intake between the heads. I could then measure around .150-.160" between the intake and heads on each side, again with no gaskets installed.
    Help, where do I go from here?
    24' Eliminator Fundeck
    Gone
    Sparks, Nevada
    You are losing me. It appears like the manifold is not wide enough for this assembly?
    When you mill...decks, heads, etc.....you are narrowing.
    So...
    Be sure head gaskets are in place.
    Set the intake on with the intake gaskets......they are about .060 thick each side. If you don't have any gaskets then use a .060 valve spring shim each side and end. Mock it up that way and see what you have.
    By the way...intake gaskets .125 thick are available.
    Senior Member VAMI's Avatar
    srq,florida
    You sure they sent you tall deck intake?
    Sounds like you have a standard deck intake. Measure across the flat of the end sealing surface. Standard deck is about 6 5/16".
    This engine is a project bigblockbill and I are working on, so I will throw in some info too. The intake is supposed to be for a tall deck. The distributor hole is machined down .400 so you can use a standard distributor on it on a tall deck engine.
    block is a Merlin II
    heads are Merlin Iron 315/320s I got from a member here on the boards.
    intake is a new Dart Intake
    Here is a link to some pictures we posted for help over on dartheads.com:
    http://www.dartheads.com/dartboard/showthread.php?t=290
    I am unable to post the pictures here because the pics aren't on my computer. Maybe Bill can upload them.
    Any help would be appreciated. Thanks!
    It wouldn't surprise me at all to find that you have a tall deck intake that's had too much taken off the flanges, especially from dart, OR- they machined the dist pad on a standard intake. Either way, it dosen't fit. Send it back and get the right one. You've already wasted more time on this than you should have had to.
    Quote Originally Posted by Airin' it Out View Post
    Apparently you can't view photos on the dartboard without signing up, so no easy way to see those photos. If I could see clear photos, I might have an answer.
    Gone
    Sparks, Nevada
    Yeah no pictures.
    But...I am thinking:
    " I could then measure around .150-.160" between the intake and heads on each side, again with no gaskets installed."
    If this were a low deck manifold he got by mistake....and since spacer plates to put a low deck manfold on a tall deck are .375 thick each side....seems there is something else going on.
    Albuquerque, NM
    Does anyone know what it would be for a tall deck intake? Its kind of a subjective measurement but the one I have hear that does not fit is about 6 1/2 plus or minus .050 depending on where I go.
    Is there any other measurements I could make that might tell me if this intake has been cut down?
    Gone
    Sparks, Nevada
    I just went out and measured the end of a BDS tall deck blower manifold and it was 6.925.
    Lexington, KY
    Quote Originally Posted by Bigblockbill View Post
    It sounds like it is a bad intake because those gaps you stated are far too small. I would send it back and have them send you another correct one.
    Pictures would really, really help!!!!! I'm not signing up to another website to view your pictures, so please post them up here!!!
    Good luck.
    HJ
    Albuquerque, NM
    Sounds like we have a bad intake. It came from ebay and sold as new and never installed a while back... guess that does not mean it was not modified first... or not good to start with... bummer.
    Here are some pics.
ID:	15097   Click image for larger version.
ID:	15098   Click image for larger version.
ID:	15099   Click image for larger version.
    Gone
    Sparks, Nevada
    Make spacers. Nothing is supposed to fit anyway. It's the hard that makes it great.
    Double your gaskets up......that will make them .125 thick. Check your port match.
    Maybe a .125 gasket each side (which are available) will get it. If not make your own gaskets or spacers. On the ends just use silicone to seal.
    It's done all the time.....ain't no big deal.
    Does look like a tall deck due to the thick flanges.
    Lexington, KY
    Here are some pics.
    They sell factory rejects on eBay. It's always risky buying parts on eBay. So I guess you cant really send it back, since you bought it on eBay.
    Do like Fiat said and use thick gaskets to fill in the gap. If it were a short deck intake, there would be a 3/8" gap on either side of the intake.
    Good luck.
    HJ
