The New Bullet is Here!!
Results 1 to 14 of 21
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default The New Bullet is Here!!
    Putting together a Dart 540 shortblock with internally balanced Eagle rotating Assy.
    What damper and flexplate would you guys run?
    For those of you who don't know me, the motor is going in a 18.5 Southwind Jet. Shooting for 800hp and around 6500 rpm.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I started a topic on dampners back when i was doing my build. End result was ATI was a great choice, maybe even the best... It's what i went with.
    As for flexplates, i was told to just make sure i get one that is SFI approved
    cfm
    cfm is offline
    ATI. Good move Shaun.
    Alta Loma, CA
    That's what I was thinkin'... Thanks for confirming guys!
    BHJ or ATI and Professional products SFI for the budget minded. Great piece for $185. Has anyone tried one of thos heavy flexplates from CSI and the like? I think they call it "the wheel" or something.
    Alta Loma, CA
    How do I know what diameter is best?
    Quote Originally Posted by XClutchboy725 View Post
    Starter and flexplate diameter must match, when using a stock style starter. Most BBC use the large diameter wheel, and the offset bolt pattern starter.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Alta Loma, CA
    Thanks, but I was refering to dampener diameter. I think ATI has 6" and 7" for internally balanced assy's.
    The biggest one
    cfm
    cfm is offline
    That's what she said...LOL.
    I'll disagree about the Professional Products damper. I've seen a few pics of them exploding - okay coming apart and flinging parts. One was in a dyno room. Thank god no one got hurt.
    Gone
    Sparks, Nevada
    Yes...I agree. I caught one coming apart also. On motors that require a balancer...have always just used a Summit SFI one. Never a problem with those.
    Senior Member vee-driven's Avatar
    Lomita so. cal.
    I would go with an aluminum FLYWHEEL or if your gonna go cheap use a certified flexplate and remember a flexplate was designed to be rigid with the use of a converter, and a ROMAC or ATI balancer.
    It's not that i don't care, I just dont give a sh!t!
    Ladera Ranch
    You building it or having it done?
    Alta Loma, CA
    I'm building it...With help from some very good consultants!
