Whats this sound!?!? New Motor... Video inside
Results 1 to 14 of 33
    Mar 2013
    Default Whats this sound!?!? New Motor... Video inside
    I just got my 408 sbc running Saturday and Im getting this sound from it. Once its warmed up it goes away and if you give it throttle it goes away. I have good oil pressure and no misfires. We started it up on the floor and this sound wasnt there. Put it in the boat and now... Kinda baffled...
    400 sbc .40 over
    Profiler Heads
    750 edel
    rpm performer intake
    9.3 cr
    Jan 2013
    Magic Mountain CA
    Warms up goes away - Maybe exhaust leak
    The rattle I hear could be inside, but since it goes away with throttle and/or warm up I'm not sure what internals would do that. Lifters with too much clearance? Doesn't really sound like lifter clickity clack to me.
    Seems like it's on the right side of video, Is this what you think?
    Working as a gas station mechanic as a kid I heard a lot of strange noises, long time ago.
    No noise on start up before installed in boat, Hmm
    Mar 2013
    Quote Originally Posted by 74Bonneville View Post
    Yeah it could be a exhaust leak.... Buddy of mine was thinking piston slap from the short skirts. But I agree... seems to be on the upper right side.
    Tower Park Resort, Lodi, CA
    What accessories were not on the engine when you test fired it?
    It sounds like it's comming from the alternator. Is the alt fan clear of brackets and bolts? With the belt off, is there any play in the alt shaft?
    Do yourself a favor and pick one of these up at the local parts store, they can be a big help sometimes.
    Automotive Stethoscope Cheep too!
    Mar 2013
    Ill go pick one up tonight, but I gotta agree with you... sounds like its coming from the alt... Look at the belt too, its all chewed up and uneven. The power steering isnt moving either....
    Ill take look tonight at clearance of any brackets and bolts and again ill pick up the stethoscope.
    Morgan Hill
    Take all the belts off and run it again.
    Also too, you sure it's not coming from the oudrive having the drive that high?
    Sure sounds like an alternator bearing or something...
    GT
    Mar 2013
    Ill try without the belts tonight, but Im pretty damn sure its not coming from the drive or bell housing area. Its somewhere on the front of the motor...
    Quote Originally Posted by chrisf695 View Post
    I'd guess the power steering is spinning just fine. Just a video illusion that occurs when something is spinning close to a multiple of 30, as most common cameras shoot at a rate of 30 frames per second. Some more, some a little less. 27-60 fps is the average spectrum, with 30fps being the most common.
    Senior Member SBS933's Avatar
    Jun 2012
    Check your flywheel if you put a different motor in it, could be flexing on you. My 2X
    Believe Nothing you hear and 1/2 of what you see.
    New here Beer:30's Avatar
    Bakersfield, CA
    That's not high at all. Shouldn't make any noise at that level. High speed trim would be about that anyway.
    I was just gonna suggest removing the accessory drive stuff. Even the waterpump (sea pump), as you can run it for a minute or less without water. No more though.
    Next would be pull the drive and then run it. Isolate as much as you can. But one at a time.
    If the video is anything lke the real sound, I'd have shut that thing off in 5 seconds.
    Now how is that going to help you find the problem. You and I have totally different troubleshooting techniques. I'd run that POS ball to the wall and see what breaks. Then you know for sure what it WAS!
    Oct 2010
    Default whats this sound
    Almost fell out of the chair... That is funny...
    Morgan Hill
    It's high if you have a bad gimball or u joints...
    Just so you know that is an Alpha.... The seawater pump is in the drive....
    Just bustin' balls...
    GT
