Circle Boat Question...
Results 1 to 14 of 23
    Jul 2009
    Default Circle Boat Question...
    Circle boats run the drive from the crank snout....at 500 hp internally balanced do you run a dampner/balancer or just a solid connection. What is the best way to do this?
    Thank you
    Quote Originally Posted by dnewps View Post
    Thank you
    Most N/A are running a damper, some aren't. Most blown deals aren't, some do.
    Jul 2009
    ok....what would you do? I want to ditch the dampner but I want longetivity and reliabilty. What is the best set up? This is NA
    If I build it, and it has 4 cylinders or more, it has a damper, blower or not.
    Got to agree with Bob on this one.
    I have a special "two piece" crankshaft sitting here to show people why I think it's a good idea too.
    Jul 2009
    do you guys know who makes one of these with the dampner built in?
    makes one of WHAT with a damper built in. I can't see what you're holding up from here.
    Aug 2009
    I agree with that!
    Tower Park Resort, Lodi, CA
    A two peace crank? You can make your own! I've made a couple over the years, but my engine's never seem to respond too well to the modification.
    Jul 2009
    a greek coupler with a dampner built in that would connect the crank sount to the drive...
    No. If you're running a damper, you either bolt the adaptor to the damper, or you run the damper on the flywheel end
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    .... I needed that today, thanks
    Jan 2011
    Mickleton, New Jersey
    Thank you
    run the dampner off the flywheel end. and the pulley for the dry sump belt on that end also
    Senior Member johnf's Avatar
    Oct 2012
    Quote Originally Posted by jimclauss View Post
    Does it bolt on?
