Engine dropping RPMs while warm and dying at idle
Results 1 to 9 of 9
    Austin Boater
    Jan 2010
    Round Rock, TX
    Default Engine dropping RPMs while warm and dying at idle
    I have a Mercury 6.2L that I am having some challenges with lately. I have replaced the ignition assembly, plugs, fuel filter wires and IAC on it. It runs really well when it is cold and even for a long while when warm. But after a good hour of running, it will start to drop RPMs. While cruising at 3500 RPM it will drop to 1500 or so every couple minutes. It is very regular on the timing when it drops RPM. It is not occasional when it drops, it is every couple minutes or so. Also when idling it will just flat out die every couple minutes.
    I have no idea. Took my mechanic out yesterday with the computer. No codes and everything looks good. He says it looks like someone turned the key off when it dies. We inverted the kill switch to rule that being faulty out. He doesn't have any great ideas about it. After he left yesterday he wanted me to clean all the battery terminals, that didn't help.
    Any good ideas here?
    2005 Sunsation Dominator 32 - twin 400 HP Full Throttle Marine 383s
    New here Beer:30's Avatar
    Bakersfield, CA
    Old fuel? Water in fuel? Does it do it on both tanks if you HAVE two tanks? Sounds like bad fuel.
    Austin Boater
    Jan 2010
    Round Rock, TX
    New fuel yesterday, other engine is running great. Single tank.
    Ada, Michigan
    Checking the battery terminals was a good call.
    I had that problem.
    Check the negative cable to the block also.
    Check any and all grounds from the ECU to the battery.
    Any fuses that are not making a real good connection can be a problem area.
    Disconnect the weatherpack terminals and spray WD40 inside.
    Austin Boater
    Jan 2010
    Round Rock, TX
    I tried checking the ground for the negative to the block, tried tracing it back but lost it about middle of the way. Where is it located?
    Morgan Hill
    Quote Originally Posted by Captain YARRR View Post
    Should be either on a motor mount or at a bell housing bolt that is configured like a stud.
    What was the fuel pressure, have you ruled out a failing fuel pump?
    Being as it runs well while cold, I am going with a fuel issue of some sort.
    GT
    Senior Member uniboarder's Avatar
    Dec 2012
    I watched my friend go through this yesterday. It was a recurring problem I guess. Bypassed the whole throttle cable assembly and hooked up direct to throttle. Bam, on the water. Its the little limit switch that cant snap "UP". Or is it because it drops down? To many electronics for me to know....
    Morgan Hill
    Quote Originally Posted by uniboarder View Post
    Do you mean the shift interrupt?
    GT
    Austin Boater
    Jan 2010
    Round Rock, TX
    Still having the same issue but noticed this weekend that as I hit waves the RPM would drop and rise with the waves about 500 RPM.
    Does this help point something out?
    I will check the throttle assembly. That could make sense, had those changed last year.
