Mechanical Fuel Pump & Regulator Question
Results 1 to 7 of 7
    Coeur d'Alene, Idaho
    Default Mechanical Fuel Pump & Regulator Question
    So I installed my new Holley mechanical fuel pump that they sent me last year at no charge..model 12-454-13 (130 GPH). They did not send a regulator they said it needed..model 12-707..I installed the regulator that I had on the Holley Blue model 12-803. After starting the pressure appears to be the same or just slightly higher..both regulators have a orifice of .220. Both regulators operate at 4.5 to 9 PSI. Do I really need to install there other regulator which costs $100 or am I good to go...
    No!
    Do I have to run the Holley one they recommend 12-704 or can I use a cheaper one...what's the problem with the other Holley regulator 12-803..Can I use a Quick Fuel Regulator 30-803 that costs $20.76 in place of the Holley 12-704..good for up to 900 HP.thanks GN7..at least I got it in the right hole..
    So What's the difference..seems to me restrictive flow is restrictive flow..what am I missing..thanks..just don't want to spend a bunch of unnecessary money..
    Quote Originally Posted by Tittyman View Post
    Do I really need to install there other regulator which costs $100 .
    Tittyman, what part of my post confused you. Read what you posted in you first post, and read my answer. Then get back to me if you are still confused and I will try to walk you through it one word at a time.
    GN7...I get it now...my mind is still dealing with the angle of the dangle and getting the rod in the right hole...thanks again..I guess no means no..I'm good to go with what I have..
    Yes, you are good to go.
