Crankshaft Endplay?
Results 1 to 14 of 31
Crankshaft Endplay?
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default Crankshaft Endplay?
    I bought a 540 Dart shortblock and today I have been disassebling and double checking everything.
    It's a good thing I did, but before I bag on anyone, I'm going to give him the opportunity to make it right.
    I have a question about crankshaft endplay...
    All I've read says BBC needs .006-.010
    I have maybe .001 !! Do they make bearings with say .005 smaller shoulder or what do I do?
    Jeff
    LaPorte Indiana
    Use some 600 grit paper on a piece of glass. Use WD 40 and wet sand the sides of the thrust bearing until you get your clearance. I set my 598" NA BBC at .007.
    Alta Loma, CA
    How do you make sure you are doing both halves evenly? Did you zip tie them together or something?
    Alta Loma, CA
    Did I mention that I love this place?.....
    Hotboat sucks!
    Default Hold On There...
    Before you start sanding on anything, loosen the rear main and move the crank front to rear and see what you get. Make sure the rear cap and block aren't shifted slightly taking up that few extra thou you need. Tighten one of the other main caps to pry against and use a small prybar or screwdriver and move the crank fore and aft with some reasonable force. Once you've done this, then tighten the rear main and re-check. It's uncomon to have so little thrust clearance.
    Steel comp is right. Take the rear main upper off (rearmain cap ) and try again. Core shift and other things will make this happen.Also I would spin the crank with the rear saddle off and see if it is smooth. Retorque and try again. Don't go setting clearances on a one shot attempt. IMO M
    Alta Loma, CA
    Alright - I loosened the rear main cap and then gently wedged a screwsriver so that I was holding the crank forward and re-torqued the rear main.
    Now I can get about .0045 by using reasonable force with a screwdriver.
    Still too tight?
    .0045 is on the tight side, but I think it's OK. I usually shoot for .0050 min, but I've heard others say less.
    Alta Loma, CA
    I just spun the crank around and it takes much less force to rotate it now. You guys were right about core shift on the main cap.
    After spinning it around a bit I can get .006 out of it now.
    I think I'm good....
    Thanks guys!
    Quote Originally Posted by XClutchboy725 View Post
    Thanks guys!
    Hey clutch, Retorque and try again. IMO M
    Senior Member VAMI's Avatar
    srq,florida
    FYI thrust bearings are only made thicker in case of a burned up crank.,A crank grinder will weld it back up and fit it to that bearing.
    waterloo
    Dart blocks have no locating pins, etc for the rear cap. So...the rear cap could go on anywhere back and forth wise. The guys have you on the right track, prying forward on the crank, then tightening/ torquing the rear main.
    Wags
    Thanks guys!
    I'm sure you could have got the same info on Hot Boat
    Sleeper CP
    [email protected]
    Ohio
    I've always done it by snugging the rear main, tapping the crank from the rear, then from the front and then torque the main. Always worked for me.
    Tim
