Distributor Gear
Results 1 to 14 of 15
Distributor Gear
    Ladera Ranch
    Default Distributor Gear
    Looking for a new distributor gear for an olds 455 with an HEI. .491 shaft. Everyone on the planet is backordered on these...what gives? Anyone know where they are in stock?
    Tri-Cities, TN
    Bronze or Cast Iron?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    El Cajon, CA.
    I just bought a .490 bronze gear for a BBC from Super Shops in El Cajon, maybe they can help you...? 619-562-4339
    If you can use a used steel gear I probably have one.
    Default Location
    Once again some one is looking for a part and we have no idea what part of the country he is in....It is quite simple to show your home town under your screen name, and it sure helps others help you in cases like this. If I knew of a gear, in stock, at the corner parts store would you come and get it?............MP
    LOUD BOATS SAVE LIVES
    Member bennyb's Avatar
    Mission viejo,ca
    [ If I knew of a gear, in stock, at the corner parts store would you come and get it?............MP[/QUOTE]
    No, you live to damn far away from him
    Go on get your ass outa here
    Default bronze or steel
    What is the best I understand the idea behind bronze, is that it will "go" before the cam.....but I also heard they suck. Not to thrad jack but what one are you thinking brendellajet??? And what is the gerneral consensus here????
    use steel gears on cast cams and bronze gears on billet cams (no cast marks)
    Cantard 71hallett's Avatar
    snow bank
    Anyone here using the melonite gears? (might have spelt it wrong) I have seen some of the stock gears chewing random teeth and this seened to fix the problem. My experiance anyways.
    Default A block?
    Quote Originally Posted by Eliminator Cruiser View Post
    No, you live to damn far away from him[/QUOTE]
    I could be on the next block, or around the corner, hell, even next door.......No way of knowing....MP
    Mission viejo,ca
    I could be on the next block, or around the corner, hell, even next door.......No way of knowing....MP[/QUOTE]
    hH e lives right down the street from me, and you do live to far away
    At the risk of sounding stupid(hey if the shoe fits right, lol) are all roller cams, billet, or not necesaraly(sp?)
    Probably not neccesrily (sp) when i learned that they didnt have factory roller motors
    Thanks H.D. I'm glad this thread cam up right now, just as an fyi what would happen if I ran a non bronze cam gear on a billet cam?????????
    I cant remember which wears out the other. My boat came with a bronze gear on a cast cam and the gear is shot.
