Ask the Bob's AKA GN7 bp298
Results 1 to 14 of 57
    Default Ask the Bob's AKA GN7 bp298
    So Bob's I have this engine and my CHT temps are High on Cylinders 1,2,and 9 The EGT's are within 75 deg over all nine. Oil temp climes to near red line at low to mid power settings. The engine is 6:1 CR with a blower I run 100LL only timing is "locked out at 25' with dual mags. The Prop is 108" power prop. Power setting is 1800 RPM 28inches fuel burn 19.7 GPH at this power. What is causing these high CHT's? On a side note you to are great to have here
    I am sorry, I don't deal in 3, 5 and 9 cylinder engines.
    First, I would dump that shit 100LL and put it on Q16.
    Second, stop running Wal Mart Tech 2000 oil.
    Is this thing a radial?
    BTW, I have it on good authority that EGT are useless information. Best to just ignore them, crank in some more fuel and boost and let let it eat. Without good accurate O2 readings, you're just throwing darts
    Jun 2011
    Is this a float plane?
    Quote Originally Posted by Checkmate21 View Post
    Or an air boat. I don't think Bottom Feeder is redneck enough for an air boat.
    Tower Park Resort, Lodi, CA
    With a 9 foot prop, whatever it is, it's not small.
    Why yes P&W R-985. It is a legit question that has been kicking my ass. And their are only two approved oils and one fuel. But hey its a 50 year old dry sump motor 280 HP from 985 inches no wonder they are "dependable" Sorry I don't support Wallys, wish the parts store was still down on the corner. Funny story back when they were open the group of racers i ran around with decided we needed a cash account so we could work toward better pricing in one year that group spent twice as much with them as their largest commercial account. But in the end that shit hole schucks, checker kragen won out, and the asshole who held the lease on the land that priced them out to put a quicky mart. Now i have to drive 20+ miles to get to another mom and pop shop. sorry rant over Whats with them -12 oil lines u need that much flow for grease you call oil not that you GN types are tough on motors
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by bottom feeder View Post
    this is very simple. 1. you need to clean the bird feathers out of the cooling fins for cylinders 1, 2, and 9 from the last seagull swarm you ran into. 2. you need a wider band egt instrument. that way, 75* doesn't look like so much. 3. 70wt kendall will solve your oil temp problems, as well as cleaning the bird feathers out of the oil cooler fins. 4. go with a 106" "speed" prop. may not get there as quick, but it'll haulass on the big end. I heard the lodi bunch has one that kicks ass and makes mincemeat out of seagulls so the feathers wont' stick.
    and I concur with the gn. jack up the boost, turn up the fuel and let it ride.
    this is as good it gits without the superwideband o2....
    Dehaviland beaver no floats. Bush wheels baby. And an air boat could be a ton of fun in the rivers no loss of thrust in the foam
    you guys great I here ya on the egt but that is as good as it gets in "approved" Just use them for overall ballance as the temp means jack.
    I understand this is a problem with some of the radial PW. But usually its with cylinders that are 4 rows back.
    Have you tried flying it at a higher altitude? Colder and thinner air. Less drag, colder cooling air, richer fuel mixture. All positives.
    4 rows back yea way out of the budget. GN7 are you going to be here for burley? yea fine at alt. or anytime ambient is 75'F. 90 to day not so good. besides i am scared of heights
    BP how is the new hot rod treating you? I need to get to another Drag Boat race allways good times.
    No, we are siiting this one out and letting someone else win one for a change
    Thermocouples under the plugs? Have you tested them by moving them aorund?
