Valve lash ?
Results 1 to 14 of 60
Valve lash ?
    El Cajon, CA.
    Default Valve lash ?
    My solid roller cam is supposed to have lash set at .020 on the intake and .020 on the exhaust when it's hot. Where's it supposed to be set at when cold? (First time being run if it matters.) Thanks!
    Cantard 71hallett's Avatar
    snow bank
    I would just set them at 20 then reset them when it,s hot.
    my .02
    Paul
    Every engine grows different. If it has a standard deck iron block and fairly stock iron heads, the growth is usually minimal. .002 or so. Aluminum heads grow more. (around .002- .003 more than with iron heads.) Tall deck blocks grow more and WOW when you get to tall deck aluminum blocks with aluminum heads.
    Just guess what they may be, but keep a good record. Then measure it when it has been hot for a while and that is the only foolproof way to test each individual engines growth.
    El Cajon, CA.
    Iron block with aluminum heads. So it sounds like they expand when they get hot (I should have known that). Maybe set them at .023 cold and then after running it for a while check it when it's hot?
    The engine is growing height wise, so you would subtract from the .020
    my cam calls for 20 also, i set em 22 cold, and i've checked them hot. the 20 was tight but fine. also runnin iron block,alum heads.
    Every iron block and aluminum headded deal I have ever ran wants to be about 4 to 5 thou tighter when it is cold. I would try about .016 to .017 cold. Then check it when it is hot. Every engine is a little different. And every engine also wants to run at different temperatures and as such, different amounts of growth.
    The clearance should "grow" .002-.004 from cold to hot. Set at .018 cold should be about .020-.021 hot.
    The Alumi heads on the 565" grow and change the valve lash from .024 cold the .026 hot.
    You guy's got me scratching my head there for a minute.
    Sleeper CP
    Senior Member hotbo's Avatar
    lake Ouachita AR
    stock cast block with aluminum heads.i se them 4thousandths tighter cold.say .020 i se them .016
    iron heads i set them 2 thousandths tighteri have checked several motors when hot and they always seem to be right on or close to it.good luck.travis
    El Cajon, CA.
    The guy that's putting the engine together for me said he wasn't sure if he could make it out until Sunday evening to finish my engine. I don't have anything to do until he's done. I don't have side work, 8 -5 work, nothing. So I started thinking I should just finish it myself. So I started this thread. He'll be out here in less than an hour to finish my engine. Thanks for the replies!!!
    Makes me wonder if anyone saw this thread...
    So, will you be using the EOIC ( or what ever it is) method or TDC ?
    Sleeper CP
    El Cajon, CA.
    Sleeper CP
    uh uh uhmmm... what?
    Set the intake at .022 and the exhaust at .024.Recheck after a real good warm-up. Please remember that aluminum heads require more heat to work and conform to a iron block. 195 running temp is okay. I may be wrong here but when was the last time you saw a REAL race care with a radiator??? For that matter what does the temp gauge say on a daily driver with aluminum heads say... I know the gauge doesn't say any thing you have to read it!!!!!!!!!!!! IMO. M
    CarbGuy RumRunner's Avatar
    Lake Lanier
    Every Cup car out there, Every Pro-Stock car out there ALL have Radiators. There are a couple of Drag Race classes that run solid (no water) blocks but the overwhelming majority run water, and radiators.
    As far as the temp they run it depends on what you're trying to do, but the colder they run the better they perform in a RACE only application. Pro-Stock cars will be about 100° to 110° at the end of a run.
