ALKY and Aluminum tank.
Results 1 to 7 of 7
    Senior Member blown86hallet's Avatar
    Belleville
    Default ALKY and Aluminum tank.
    Need to know what needs to be done to an aluminum fuel tank when running alky?
    I heard anodizing is the answer...?
    I will be running the boat on weekends, does the fuel need to be drained or can it set for the 5 -7 days in an alunimun tank?
    "Jealously" is an ugly emotion!
    El Cajon, Ca.
    Hard anodize is the hot ticket. It is a good idea and practice to drain it out after each use and flush the system... but I have gone a couple of days before and not had a problem.
    The Bostick®
    Build a stainless tank is the hot ticket. Hard anodize will hold up better than bare but any scratch and the corrosion begins.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    i know several guys running spun aluminum tanks, they dont drain the tanks, or the lines, everything is fine.
    However, its a gamble, methanol does react to aluminum, (no laboratory scientist) just what I was told.
    I bough a polished stainless tank for a dune buggy, affordable too.
    waterloo
    Imco marine has several sizes of SS tanks. They will also custom build whatever you want.
    I am one of those not always draining guys. I wish I wasn't. It should be done. But, most of the alcohol fuel addative lubes help greatly with corrosion also.
    Persoanlly I run Pro Blend, or Redline lube. Both 2 thumbs up, in my experience.
    Wags
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Alky will turn to jelly. Not sure on how ling it takes but it will turn...
    Steve
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by Roaddogg 4040 View Post
    Steve
    takes a long time to do that. I go for weeks and no problems. seal the tank when not using it . Alky will draw water.
