Will this combo suck ???
Results 1 to 14 of 33
    Default Will this combo suck ???
    Lookin at 427 bbc(not tall/truck block) brodix bb2plus heads.(cc'd at 116), srp piston #141637 prox 9.5 to 1, comp solid roller # 11-703-9 .680 lift. vic jr. intake, 800 dp holly. bassett tt headers. There aren't many .070 pistons out there , but if this combo is going to suck I'll pop for a new block. I'm considering/ have been talking a little to cstraub, wondering if a custom grind would be worth the extra $$?? Any sugestions would be greatly appreciated. OH BTW it's going in a jet boat.
    cfm
    cfm is offline
    Not good for your combo. Did you call Comp ?
    For others, here's the spec card for 11-703-9
    http://www.compcams.com/Cam_Specs/Ca....aspx?csid=516
    Is 9.5 to 1,, too tame for any solid roller cam?? I dunno I have a set of 11.6 to one pistons, I'm just sick of needing to mix 110 with pump gas.
    put the 11.6 to 1's in and have chris grinf you a superunleaded capable cam for it, its not outta the question
    ptz
    ptz is offline
    so ca
    get a different cam.
    Lurker
    NC
    What isn't good for his combo?
    cfm
    cfm is offline
    The cam for his compression, cid, and operating range.
    That cam has some mama lama durations.
    As always, take my info with a grain of salt and treat it that way.
    Not at all. There's solids out there for most everyone. A 9.5:1 motor can run pretty hard.
    Give a few calls to Comp, Lunati, HArold Brookshire, whomever that is on top of their game and you are comfortable with. Then sit down and decide what you'll go with.
    Thanks guys, I've rattled Chris's chain so many times I'll put my cam fate in his hands.lol It would be nice $ wise to be able to reuse those 11.6 pistons.
    Lurker
    NC
    Not a bad choice on cam guy's!
    I'd whack a little off of those domes, blend them and cam it accordingly!
    Cantard 71hallett's Avatar
    snow bank
    hrrmmmm 701-9
    Tri-Cities, TN
    Brodix heads like duration split so I would recommend going with something with some more split. The heads respond to this and customers engines have made very good power.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Chris is the man, cant go wrong with him. Have yet to see a bad review about a cam he did too!
    Default compresion wise??
    I know I can't go wrong with cstraub. I've bugged him so much I feel like an ass. FWIW what would make the best pump gas build , solid roller , 427 bbc. alum head,,build?? Short block wise 11.5,10.5, or????????
    Dude...quit bouncing around, pick a combination, and go with it. Whatever your combination is, go with Chris or call me and I'll help you out. 805 350 1159. With the right cam your combination will work just fine. Don't waste your time going through off the shelf cams that might come close to what you need, just get the right cam and be done with it.
