E85 spark plug suggestions?
Results 1 to 13 of 13
    Senior Member jrider44's Avatar
    Brainerd, MN
    Default E85 spark plug suggestions?
    I have a 13:1 452 BBC, 049 iron heads, Mark Sullens E85 carbs converted 850 DP. Any suggestions on spark plugs and heat ranges? Would like to run NGK and need an NGK number. Thanks, Jason
    1978 Hawaiian Party Cruiser
    Stevens V-drive(sold to bbollig55)
    Spico V-drive
    Ada, Michigan
    I run NGK V power 8
    Jun 2010
    stock # 3442 R5673-8
    Placentia, CA
    X1000!!!!!!!!!
    steveo143 AKA DiMarco 21 II
    Brainerd, MN
    Quote Originally Posted by mdsheppie View Post
    Will these fit an iron head with tapered seat?
    Spico V-drive
    Jun 2010
    Quote Originally Posted by jrider44 View Post
    Yes
    Brainerd, MN
    Carb builder recommended NGK -7. Is that hotter and would that cause any problems?
    Spico V-drive
    Jun 2010
    its hotter might work tho Ive used them but the 8 was a better fit with a blower ....It would be the same numbers (5673-7) the other numbers-3442 aren't necessary when you buy them
    Brainerd, MN
    Quote Originally Posted by steveo143 View Post
    X1000!!!!!!!!!
    What kind of engine set up do you run?
    Spico V-drive
    Placentia, CA
    496 BBC with Race Arrow twin turbo @17# boost. Currently switching it from carbs to EFI.
    Brainerd, MN
    Thanks guys. I bought R5673-7's and might bring -8's with to the dyno on tuesday.
    Spico V-drive
    Peoria, AZ
    Let us know how it goes.
    Paul
    Brainerd, MN
    Paul
    Dynoed engine today used the 5673-7 plugs. Mark Sullens E85 carbs did a great job on the carb! No changes made to carb...bolted on and ran. Made 516lb-ft at 4500 and 505hp at 5700.
    Spico V-drive
