Cam GURU, who to ask ?
Closed Thread
Page 1 of 26 1 2 3 4 11 ... LastLast
Results 1 to 14 of 364
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    Default Cam GURU, who to ask ?
    I'm running a 112 cam in my blower motor. I've read that the 112's have more EGT's compaired to the 114's ? Is this a true, good or bad ??? If I was to get a new cam made, who would you call ? Am I better off calling a large manufacturer like comp who has a book that says put this cam in, or ???
    I know I'm asking for peeps opinions, and that's what I'm after. BTW it's a 521 Ford currently running 8-9 lbs on 92 pump.
    Lurker
    NC
    Quote Originally Posted by DaytonaTunnel View Post
    Get ahold of Cstraub here on the boards. He can set you up.
    And yes, typicaly a blown deal (especialy with some good pressure) really likes opening up the lobe seperation (around 116-118 but I'm not a blower or a cam guy). That way, the intake charge that is under pressure doesn't get blown out the exhaust during overlap, thus raising the EGT's (and hurting cylinder fill).......or something like that!
    Call Chet Herbert racing and talk to Chet Or donny Johanson. Both have been grinding cams and racing for a LLLLLLLLLLLLLLOOOOOOOOOONNNNNNNNNNGGGGGGGGGGG time. They are in Chino Ca. Phone 909-393-4597. Or you could ask Doug Herbert. You know the top feul guy. But he will just ask his dad.
    waterloo
    Gas or Alcohol?
    Ultradyne makes some nice stuff, easy on valve train parts.
    I would go with a smaller company..more specialized than a bigger company. Do you go to Earl Schibe or a custom body shop? Same thing.
    Wags
    Cantard 71hallett's Avatar
    snow bank
    I think you are going to spend some money and do some work and gain something around 0
    What are your EGTs now?
    Enumclaw, WA
    Don't know what the EGT's are, but the exhust gets hot like right now !!! Was wondering if the 112 was adversally affecting anything or not ?
    What is your base timing and your total timing and at what rpm do they occur?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Agreed. Chris is a great guy... Put up with all my questions and decision making. Have yet to see anybody who was unhappy with the cam he designed for them. Send him a PM or give him a call. Here's his website http://www.straubtechnologies.com/
    Enumclaw, WA
    Thanks for the link, I might just call and bug him a little.
    Timing is 32 locked, backing down to 28 under full boost.
    A.J. Arizona
    Is this a Centrifugal or a Roots Blower? Inner Cooler or No Inner Cooler?
    It Sounds like a tune up problem, If its a roots blower with no inner cooler you have to much boost for 92 fuel, And your probably adding fuel and taking timing away to make it live, which will in turn make your EGT's go through the roof.
    Jay
    Chris only runs about 100, lol his combo sucks baaaaaaddd. I dunno, in all my dumb ass asking about a/f ratios, for the most part I've heard over and over, egt temps as far as a tuning guide are way over rated. (I realize that's not exactly what he's askin) BTW he' running a roots type, with an intercooler.
    A.J. Arizona
    With an inner cooler you can run 8-9 psi boost with 92 octane, depending on what your comp ratio is, determains how much timing you can run. Less timing Higher EGT's more timing lower EGT's. Too much timing Detonation! There is alot of trade off's When tuning a Blower motor. I never tune using EGT's But they are Important in keeping your Combo safe.
    Lobe centers alone don't determine much of anything...it's like evrything else, all about the combination. I'm building a blown 489 BB Chev with a custom hyd roller (blower cam) that's at 112. Does that mean it's right or wrong for your application? No, just showing you that 112 by itself is acceptable in a blower app.
Closed Thread
