twin turbo sbc help
Results 1 to 7 of 7
twin turbo sbc help
    Default twin turbo sbc help
    just spent the day on the dyno with my twin turbo sbc its a GM sportsmen block 4.125 stroked to make 380 cuin afr 195cc eliminator head 8.8.1 compression super victor intake on a 750 blow through carb from CSU with twin turbonetics gtk 650 66mm comp 65mm exhaust with 40mm waste gates from turbosmart on each bank now my problem is with a 5psi spring an hose coming right off the turbo to waste gate an plumbed correctly it was boosting 14-16 psi we even took the springs out an ran with the gate open its just slowed the boost curve down but still did 14 psi is the waste gate to small I only want to run 10 psi its for my 67 chevelle street king car on the funny side it did 899.6hp [email protected] 16psi an 876hp 14psi I stopped making pulls cause the boost kept running away the motor still has 500 to 800 rpm left at 6000 it had not peaked yet sooo what the hell
    okie, lake Texoma
    Quote Originally Posted by neil450 View Post
    Gates to small, or poor placement. We have had the same problems even with dual 60mm gates and correct placement. We cured it by adding a cheap $35 BOV to the charge pipe with a light spring and let the boost blow it open. A controlled boost leak if you will.
    Then I added a solenoid & put a button on my steering wheel to close the bov if you want to add the power.
    H8-2-W8
    [email protected] first pass
    X2 gates are too small.
    that solenoid you use on the bov, ya think itd be ok with watermeth flowing thru it? Wanting to put a hobbs and solenoid on my 3rd injector preturb so it doesnt turn on till 16lbs(8lbs after the first two turn on).
    I'd go ahead and do it. Whats the worse thing it could do?
    GO
    I think it will fine if you don't have a magneto and rev limiter
    I'm not trying to get to technical its just a street car I like to Cruz so 10psi was the limit its none inter cooled an I thought about water/meth injection but 10psi is border line I don't know if it will pull that kind of boost on the street may not load as hard like the dyno would 45mm wastegate make any differnces this was the last pull at 16psi 112 fuel 27 ° timing
    okie, lake Texoma
    GO
    He doesn't have to worry bout it Bob, he runs puny stuff like you do. So he wont see the problems some of the more powerful stuff deals with. Any old ignition system will work with that small stuff. Hell, even a set of points/condenser & coil will fix you boys up.
    H8-2-W8
    okie, lake Texoma
    I don't know if it would stand up to that or not. I'll pm ya the part # and you can research it.
    H8-2-W8
