Carb Tunnel ram ???
Results 1 to 10 of 10
Carb Tunnel ram ???
    Placerville/So Cal
    Default Carb Tunnel ram ???
    I have a 486 BBC 12.5 to 1 comp. 720 ish lift cam (have too look) Dart iron
    eagle heads. edlebrok Tunnel ram. I have a set of 1050 dominators.... I know thats too much carb, but can I make it work???
    "Never Trust A Fart"
    Senior Member tx-19's Avatar
    wittmann,az
    yes
    No problem. I had a pair on my 467 with a smaller cam. Made 820 hp.
    Show off
    I thought you were headed to Bonivelle this week ?
    Sleeper CP
    Just trying to give some support to the advice.
    We leave oh-dark-thirty Sat AM. Freekin car is OUTstanding!! You need to send me your email so I can send you some pics.
    PM sent.
    What class and what speed are they shooting for ? I thought it started this week ?
    Sleeper CP
    AA gas lakester. Set up started this week, but time trials start Monday.
    This is a brand new car from the ground up. Old car held 12 different records, and put six people in the two club, and three in the three club. Went 320-something with 1100hp small block (crashed at 316 after about 40 yrs on the salt). New car has as much power, better body and engineering. If this car goes down the track with no issues it should run 300+ easily. I think the standing record is 260-something, so we should come home with that. Ultimately there's a twin turbo in the future, and speeds in the 350+ range.
    Nice. Good luck to you and the team.
    Sleeper CP
    Placerville/So Cal
    IS my best bet to put these to stock out of the box and run from there?
    Quote Originally Posted by Lilflattie View Post
    Usually, yes. Which 1050's are they?
