edelbrock progressive nitrous controller
    Dec 2012
    Default edelbrock progressive nitrous controller
    Are any of you guys running this programmer on your boats i have one on my canyon and cant seam to figure this thing out. Here how i started mine at a 10 percent building to 50 percent over a 9 second period it just doesnt seam to work at all i cant set it at a 100 percent and tag the micro switch works fine but the build part doesnt work right without the motor started it builds and seams to work. Just wondering what everyone else is doing to make theres work and i have 250hp pills in the fogger.
    El Cajon, Ca.
    Seems like going from 25 hp to 125 hp over a 9 second time period would almost be unnoticeable as far as the "seat of the pants" goes.
    The Bostick®
    Dec 2012
    Default nitrous
    Only reason im going with such a small shot is my boat runs a 9.20 when the motors right without nitrous so if i go with a full 250 shot it will run well in the high 8s just wanting to take the .20 out of it. Might just start messing with props and gears and ditch the nitrous i think i can get it in the 9.0s with a little better setup
    031 RIVER4FUN's Avatar
    I don't have the programmer but I use a timer for the nitrous. Usually I run the 250 shot for 2 seconds on the top end to run the number. Just adjust the timer to fine tune it.
