Bottom Feed Needle and Seat
Results 1 to 14 of 19
    Atlantic Beach, FL
    Default Bottom Feed Needle and Seat
    BLP makes a needle and seat that only discharges from the bottom, and they claim that prevents aeration of the fuel in the bowl. The idea is that fuel enters below the liquid line, not splashed over it (at least, that's the way I understand it).
    Their website shows a modified carb with windows cut in the bowls, and on one bowl using their needle and seat the fuel is clear, while the other bowl with the standard needle and seat the fuel looks all cloudy, presumably aerated.
    If you have experience and/or KNOWLEDGE of how these bottom feeders work, please share your thoughts!!!
    Lurker
    NC
    They work VERY well!
    Kingman/Golden Vly, Az
    do u have any p/n?...i have seen them before & i can understand the theory & it makes sense
    FastRat
    it's not a needle and seat, it's a re-designed BOWL. And they are bank!! Nice but not cheap. Bill unless you are haveing a problem controlling you fuel flow thru the carbs,find somewhere else to spend a small fortune that will really help. You seem fixated on float and bowls for some reason. Triple throw down chromed out float bowls with notched floats and jet extentions aren't going to help you much! Maybe try a MSD
    Lurker
    NC
    Default Down flow seats
    Yes, the new "Down Flow" needle and seat assy. will fit in all older center hung bowls. They do a great job of reducing fuel foaming and aeriation in the bowls. This helps to stabilize the "useful" level of fuel in the bowl. Going to a larger needle and seats helps to calm this down also (.110 vs. 128) and neither require changing of the fuel pressure.
    Oops, my mistake. I thought he was referring to Braswells "CHUTE" bowls, which take the concept one step further for those with really deep pockets
    i'm a little confused!...r u saying a .110 n&s is bigger than a .128 n&s?...also...can u chng the n&s to a larger sz in a DP & stabilize/calm the fuel in the bowl?
    FastRat
    Lurker
    NC
    FastRat
    I confuse myself allot at times, especialy when trying to explain my thoughts to someone else!!
    I meant going to a .128 from a .110 helps to control incoming fuel also, even with a standard design. But if you go to the .128 down flow's from a .110 standard there is a big reduction in foaming/aeriation thus increasing the quality of the fuel in the bowl as the main jets see it.
    Lurker
    NC
    Dave is the Shiat, and he was all we ever used until the Holley situation developed.
    His "spread bore" 4150 type carb is a VERY nice piece, I wish we could use them!
    okkkk...i got it lol ...do i have to chng the squirters from stock? & do i have to chng the acc pumps?...can i keep the stock jets?...the carb to be used is a Holley 4777-2...650cfm DP, mech sec
    FastRat
    Lurker
    NC
    FastRat
    All systems remain normal (squirter/accel pump size and float level setting), except that it may require a SLIGHT change in jetting. At the most you may see a 1-2 jet differance (richer) due to less aeration of the fuel in the bowl. Prolly wouldn't see it on most plug checks but definatly noticable on an O2 system. The trend is for the fuel curve to flatten out some as things are far more consistant in the float bowl throughout fuel flow/temp and engine speed variations.
    This might be adjusted best by a small change in HS air bleed size, but it has been a few years since I have been in the thick of the carb deal.
    Well you can't be the resident expert if you're off the curve, now can you. Please do what you can to get yourself cought up.
    Atlantic Beach, FL
    Warp - I really appreciate your feedback. This is all about learning the fine points of tuning, consistency, and reaching a programs potential.
    The bottom feed needle and seat seems like a no brainer.
    The carbs are apart and freshly cleaned since Long Beach. They are going back together with these, BLP float springs and Braswell offshore floats.
    OK...i searched there website (if i have the rite 1?) and cant find any info on them ...do u have a link?...any help would be appreciated
    thnx FastRat
