milkshake anyone!!!!!
Results 1 to 14 of 22
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Thumbs down milkshake anyone!!!!!
    well my uncle mark has turned his motor into a milkshake
    he ran it hard very hard since the build.he was out friday and held it to the floor for about 2 miles down the lake racing a fountain boatwhy i dont knowbut anyway he said it just started losing power like he was letting off the gas and he still had it to the floor till it just died
    he brought it to the shop and i pulled the dipstick full of milky water
    im thinking intake or head gasket
    what is the best way to check this????its a bbc with cast iron heads.hg are felpro 1037 ive never had a problem with them the intake were edelbrock gaskets rect.thanks guys for anyhelp
    Blew a head gasket, intake gasket or broke something to let water into the oil.
    Get out the wreches and get to work.
    Brian
    back all the rockers off and pressureize the cylinders with air, use you leakage tester for that you can also pressureize the water hoses to the motor to pump up the block with air, that's my fav way on a boat.
    Compression check it before you do any head removal.
    lake Ouachita AR
    okay thanks guys,this evening im going to put my leakdown guages on it and go from thereill post my findings
    Ladera Ranch
    could be simple as a manifold leak...Use 3m weatherstrip adhesive on the water ports. Have used sevral times with excellent success.
    Newton Ks.
    I've done this with small ammount of RTV and had no problems. Both sides of both gaskets.
    I have heard that they almost beg to leak if you just put the intake gaskets on un-touched.
    H.L. Mencken
    Why is no one telling him to check his bearings????
    think he going to check them with the old "ACID TEST" once he gets it running again.
    Senior Member Gravyboat's Avatar
    Commieland
    Did he notice the temp at any point before or after? If it overheated, it might end up being more than just a gasket problem.
    Freedom Without Authority is Anarchy.
    Authority Without Freedom is Tyranny
    “The trouble with socialism is that you eventually run out of other people's money”
    –Margaret Thatcher
    Ladera Ranch
    Im sure that works. Im sure he did it when he built it too. On an engine that leaks at the manifold once though, its worth it to spend a couple bucks and use something that works better than RTV IMO. That way you dont mess with it again.
    cfm
    cfm is offline
    I've used 3M weatherstrip adhesive on high water psi applications.
    Some that I know use holymer (sp?).
    Low water psi seams fine with thin coat rtv but I still use a little 3m weatherstrip in middle of gasket (between port pairings) to hold gasket in place.
    One of those "Whatever you are successful with's."
    i use the 3m weatherstrip adhesive too, gaskets don't shift using it like they do with silicone.
    lake Ouachita AR
    check gauges he doesnt know what that means
    i havent been able to check anything other than drain the oil,the shop is tied up with wrecks and its been raining here forever
    as far as the bearings im gonna pull the damn motor out and tear it all apart.i got to thinking well if he held it to the floor till it just diedwell i would hate to find it to be just a h.g. or intake gasket then put back together and knock,knock or no oil pressureso for once im gonna be smart,lol or try to be anywayhe has put alot of hours on the motor and this is the 1st problem,i did use black silicone on all the water ports,but if you remember the fun i had.i had to machine the intake to compensate the major milling of the block when all this happened during the build and i never did like the way it fit.so i will find out soon enough i hope he didnt destroy the whole thing
