drain bolt help
Results 1 to 7 of 7
drain bolt help
    MD
    Default drain bolt help
    does anyone know if the drain bolt on a milodon oil pan use's a gasket type or o-ring on the 12an drain bolt
    mine fell apart but it looks like a flatten o-ring
    and where can I get one ???
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Where do you live? Look up any industrial seal business in your city. Take it to them.
    QE 439 Twin Turbo
    MD
    I had a brain fart and left the 9 pieces of it (o-ring) and the bolt at my shop and its 2hr away
    im going to go to a hyd. shop and see what they have.
    I just found that it's
    -12 an
    1-1/16 - 12 thread
    New Port Richey, FL
    OK then it is a -12 ORB (O ring boss) that threads into the pan. It should just be an o ring.
    Tell the hydraulic shop that and they will give you the right one.
    QE 439 Twin Turbo
    MD
    Thanks info. im heading out now
    Redding, CA
    I have a new Milidon plug with the O-ring.
    From that type pan.
    I'll send it to ya if you need it...
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    MD
    From that type pan.
    I pick up two O-rings one is thicker than the other
    can you sent or post a pic of yours and a measurement id and od
