Pushrod length/rocker geometry
Results 1 to 14 of 30
    Member Romper Stomper's Avatar
    Dec 2011
    Default Pushrod length/rocker geometry
    I've got to determine the pushrod length on a Pontiac motor and I'm not sure what to do. I know you run the cam to mid-lift and make sure the rocker is 90° to the valve stem and the roller centerlines match up. My problem is, I'm using a skid ball rocker with a roller tip and I'm not sure where the skid ball centerline is. Im thinking it would be at the top of the ball/base of the polylock. Any suggestions? Thanks in advance.
    Quote Originally Posted by Romper Stomper View Post
    For what you're doing, that's going to be plenty close. If somehow you can figure the radius of the ball, then you could use that but I think you're going to be fine.
    Although 2 balls stacked atop each other isn't a perfect sphere, the top of the ball is close enough for the type of rocker, and the lift you are dealing with.
    However I will warn you that many of those rockers are just copies of the original stampings with a longer slot. Many(most) OEM stamping were designed around the 1/3-2/3 arrangement, Be sure you don't run of slot if the PR has the rocker starting somewhere other than the full closed end of the slot.
    Dec 2011
    Does this look ok?
ID:	332817   Click image for larger version.
ID:	332825   Click image for larger version.
    Does this look ok?
    How much lift? Push rod looks a little long. I like the '56 better...
    Dec 2011
    The cam card says .510/.520, but I'm getting .524/.534 on the retainer.
    do the math on the rocker on both ends! If you are running a 1.7 rocker the cam lift is .305/ 314. Then do the x 1.7 to get lift at the valve.
    Dec 2011
    Read my original post. It's a Pontiac. Most Pontiacs use 1.5 or 1.65 ratio rockers. I'm using 1.5. Cam lift is .340/.346. I'm sure you can math up the rest...
    Dec 2011
    You were right... Full on rollers are on the way.
    Dec 2011
    Ok...how bout now?? The lobe lift on this valve is .347. The ratio on the rocker is 1.5 so that should yield .520 on the retainer. I'm actually getting .557. What am I doing wrong? Or is this ok?
ID:	334849   Click image for larger version.
    Is that valve open, mid, or closed?
    Based on the numbers you got with the cast rockers and these, I am beginning to believe that cam is a pinch bigger than they said it is.
    Sorry if I sounded insulting. Is this a solid or hydraulic build? I thought maybe it was a pontiac head BBC. Doing the math I have questions about why you are coming up with that much lift? M
    Dec 2011
    In the pic it's mid lift. Before I put the heads on, I checked the lobe lift. The cam card says .340 lift and it measured out dead on. Do you think I have the adjustable push rod too long? The rockers I'm using were highly recommended by some Pontiac gurus and the roller is pretty damn close to the center of the valve stem.
    Dec 2011
    No worries, man. It's a poncho all the way. Hydraulic roller. Doing the math, I have questions about why I'm coming up with that much lift...
