Header gasket question
Results 1 to 14 of 21
    Boat 502 76Miller's Avatar
    Huntington Beach, Ca
    Default Header gasket question
    I was wondering if any of you guys that run your headers dry for long runs down the river ever burn up your header gaskets ? I used to run water to the pipes on the last motor but not this one. Is this normal when running them dry ? I didn't use any silicone on the gaskets, just ran the ones Bassett supplied. I started to hear a little exhaust leak over the weekend and I don't have that much time on these gaskets. Motor doesn't run hot, and it wasn't a valve train noise because I lashed the valves today and they were fine. I do run the boat for long runs, not just 1/4 passes. Last thing to add, I have the water injection lines plumbed into the headers and they are not attached to water lines or plugged off....could this be a problem ?? Should I plug them off ??
    I run the plain ol felpro metal deals, like for a stock exaust manifold. If your runnin them paper ones , kill the guy that gave em to ya. You will get alot of answers here alot of guys just sillycone em. Just re-read your post when I said silicone I meant no gasket.
    Cantard 71hallett's Avatar
    snow bank
    I probably drive like you .... long runs. I use the black felpro gaskets, after the first little run you will want to go ever them again when they are cold. No problems here. What gaskets came with the headers?
    Nobody
    Big River, Ca
    All I've ever used are the cheap ole MrGasket gaskets, never a problem!..
    snow bank
    Quote Originally Posted by GoFastRacer View Post
    Sounds like he just needed to go back over the bolts unless he got those white paper things.
    The bolts where good and tight. I went over them every time I ran the boat. They were good gaskets too, I need to look again to read the brand but they were not the cheap paper kind. Kind of weird ??????
    Wayne nice talking with you on Saturday. That's one nice Ford you have there Great detail work you did on the boat too.
    I used to blow gaskets out alot; switched to just using High Temp RTV gasket maker. I think I now have the RTV Ultra Black. I can't say it has never blown out on me but nothing like the gaskets use to.
    You may also want to use studs with brass nuts, they don't back off. On the gasket maker you can put it on wet or put a nice bead on the header and let it sit for 1-2 hrs and then put it on. Either way has worked for me.
    Lastley, the gaskets use to blow out on long NOS passes the high temp gasket maker is much tougher.
    Sleeper CP
    no water in my pipes and my gaskets are two years old and still seal tight.
    check to make sure the two mating surfaces are straight. warped header flange will kill gaskets.
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I was killing header gaskets every trip, i run my headers wet. My flange was warped at the top of each exh port. If you find yours warped and cant find a place to surface them let me know, i searched all over the place and finally found a place local to me to do them, Only made two trips on them but so far so good, i used to blow out the gasket in one day!
    Default Thanks for the advice guys
    Sleeper-
    It was good talking to ya. Wish I could of made it down on Sunday but I was pretty worked from being there all week and had alot of packing to do. I really didn't feel like running the boat when I started hearing the leak either.
    Cyclone-
    I didn't check to see if the header flange was warped.....brand new pipes. I will check tomorrow. That would make alot of sense, and could be done w/ it. You heading out to BR on Labor Day ?
    Shaun-
    If thats the case, I'll shoot you a pm if I can't just fix it myself. Thanks alot
    i run dry upswepts with copper oring embossed gaskets from summit racing, their 2.25 round gaskets are only 29.95 reuseable and there's is nfw you can blow 1 out.
    Senior Member rivertime247's Avatar
    REDONDO BCH SO CAL
    Default Earls
    WAYNE ...WE USE THESE ON OUR BBC AND NEVER ANY ISSUES.
    EARLS PRESURE MASTER HEADER SEALS
    http://www.holley.com/29D04AERL.asp
    El Cajon, CA.
    I'm glad someone else asked the question because I was getting ready to ask the same question. I trip out, maybe 4 or so hours, and a blown header gasket. Engine was running hot. I was thinking of using the summit copper deals and I'm going with that. I'll let you know how it goes but it might take a while for the reply. Header flanges are slightly warped.
    Quote Originally Posted by 76Miller View Post
    Sleeper-
    Cyclone-
    Shaun-
    Si. we'll be there.
