Olds pushrod guide question
Results 1 to 5 of 5
    Senior Member TrollerDave's Avatar
    Chino,CA
    Default Olds pushrod guide question
    I had a loose rocker and it ended up wearing into the guide. I've looked for a replacement, but everything for an Olds
    looks different than what I got. I got a new rocker but when I go to tighten it, it still is able to slide because of the groove
    in the guide. Can anyone point me in the right direction to get a replacement guide?
    Also, how would I even get the rocker arm stud out?
    Thanks.
Name:	July 2013 091.jpg
ID:	337377   Click image for larger version.
Name:	July 2013 142.jpg
    Chino,CA
    Here is a better pic of the wear on the guide.
Name:	July 2013 141.jpg
    Senior Member VAMI's Avatar
    srq,florida
    That's a conversion kit to switch from bolt down to stud mount.Crane has those for ford and it looks like the guide and plastic insert are the same.
    Senior Member jamesblown97's Avatar
    Mar 2011
    st george ut
    to get the stud out put 2 nuts on the stud and tighten them together and remove stud using the lower nut that's how I have done it in the past a couple times I had to use 3 nuts
    Chino,CA
    Quote Originally Posted by VAMI View Post
    That's it . Thank you very much.
    Doubling up nuts is how I thought. I just wanted to be sure.
    Thanks again.
