Lash setting solid roller Ti intakes
Results 1 to 13 of 13
    Default Lash setting solid roller Ti intakes
    thought this was pretty good:
    278/284 @ .050, .780 gross lift
    Set the lash before the 4th July weekend: set at .024" cold
    three day weekend put about 110 miles in the engine. Went back last weekend and put a bit over 30 miles on it on Saturday.
    Decided to run the valves tonight and 15 of the 16 were just where they were 140+ miles ago. # 7 exhaust was a tad tight.
    Jan 2011
    Mickleton, New Jersey
    Decided to run the valves tonight and 15 of the 16 were just were they were 140+ miles ago. # 7 exhaust was a tad tight.
    good for you most people aren't that lucky.
    Sleeper, Don't beat your'e self to death over it! As I am sure you already know it is real easy to run valves and be coming on the ramp (or off) and miss one once in a while! Run them again and recheck! The best part is the valves don't grow on a cam or lifter problem! Good luck! M Normally a valve adjust will grow with a failure in the cam or valve train My bad!!! I am beyond sure you know what you are doing------everybody is human!!!
    Hard to beat shaft rockers and lash caps for holding a lash. Says a little about the camshaft too that doesn't beat your valve train to death.
    Like Old guy said, don't beat yourself up over it
    Senior Member 65BEAVER's Avatar
    Nov 2008
    livonia mi
    Congratulations on a stable happy valve train w/out harmonic issues. No mix matched parts or flexy flyer pushrods. Shaft mounts help too!
    You need to look into buying the lsm lashing tool. Its not a option when it comes to lashing a engine. Its a built in torque wrench also. I've been using them for probably 10 years. It really speeds it up. I'm sure you might not care in the boat, but at the dyno or between rounds there help full. There spring checker is the shit too. Its only $240. I've used $1,100 buckston ones and the lsm one rocks.
    One of Dan Crower's specials ... same cam since 2003. Most of that 140 miles was done at over 4,000 rpm on long runs.
    Quote Originally Posted by 65BEAVER View Post
    I know the tool you're talking about.... been meaning to buy one for at least 7 years, but then again I've been meaning to join the So Cal Procrastinators club for the past 18 years, just never seem to get around to it.
    The LSM lashing tool is a life saver. Cool thing about it is you can use it to torque the Torx bolts that hold the rocker to the stand as well.
    Quote Originally Posted by jimclauss View Post
    in 07-08 before the beryllium seats my first set of Ti valve wore like crazy. this is much better.
    Who's valves?
    Who's valves?
    Manley ... they started as 2.40's ... they'll now make a good set of 2.30's ( they are set aside for another use)
    Un-coated
    Un-coated
    Manley's in this build as well?
    Jan 2012
    lake Charles, Louisiana
    I have a couple of them LSM lash tools, hard to beat em
