water meth injection info
Results 1 to 14 of 21
    Default water meth injection info
    I have a twin turbo SBC none intercooled carb blow through on 10 psi I been looking into water/meth kits I have never even messed with the stuff I have looked at the snow an AEM kits for carb set ups its a 67 chevelle an I may try an fab a intercooler setup but if water/meth is a good idea then I wont have to cut the car up so what are the pros an cons on use an install I was looking at the carb plate option I dyno the motor an pushed 14psi an it made 900hp [email protected] it still had another 800rpm but was worried about not being able to cool the charge
    Nov 2009
    Devilsown
    Hmmmmmm ok so no one on here has messed with water meth injection
    Quote Originally Posted by neil450 View Post
    Devil's Own is a meth/water system.
    Yes, Impatient(member) is a serious meth user and whips up his own meth.
    Methanol Injection : Water Injection : DevilsOwn Alcohol Injection - DevilsOwn Injection
    Senior Member Skydog's Avatar
    Jul 2010
    I must add meth rocks!!!! I push it way to far on pump gas and boost. Have not been bit yet love the stuff!!!! I use it on boost sleds. I am realy thinking about putting it on my boat. So I can run more boost safe.
    Jul 2010
    Not trying to steal your post but who makes a kit for under my carbs? Is there a plate or just drill in a few nozzles?
    Ty
    Well that clears that up through my searching I never found devil owns so I was scratching my head on that post
    Quote Originally Posted by Skydog View Post
    Ty
    I found the plate on alcohol injection systems.com
    Jul 2010
    Thumbs up
    I am going with this, they were Awsome on the phone!!!! For sure know there stuff!!
    The Best Water injection system and water methanol injection systems at AlcoholInjectionSystems.com
    Nov 2009
    Sorry, Thats the place I'm going with. I'M looking at a system to inject in the manifold After the inter cooler on a twin turbo BBC. It will turn on at 10 lbs thats the plan anyways, Still a ways out.
    Jul 2010
    Thumbs up
    Yea talked to owner he rocks! Will do next week and post pics!
    cool thanks im thinking the plate under my carb im getting the clip back on the car here soon i will see how much of a pain it will be to try an get a intercooler in there so the water meth is pretty straight forward just buy the pre mix gallon jugs install the system set the pressure boost sensor an good to go
    Mix your own or you will b paying for half gallon of distilled water buyin that premixed stuff.4 bottles of regular yellow bottle heet brand water remover to 1 gallon of -20 washerfluid equals a nice cheap 50/50 mix and for less than 6-7bucks. i run a turbo ls blowthru to 18lbs on pumpgas 93octane with a bigg turbo making the boost.i run no intercooler, have a 5 nozzle on each side of hat entrance and a 4 nozzle shooting into my turbo preturbo at 200psi and use a 5qt(1.25g) tank i have a hobbs switch turning on the meth pump at 8lbs.i put a l.e.d near my boost gauge and wired the voltage side of it to the voltage side of methpump so i can see when it turns on..only time ive hurt something is when i ran the watermeth tank too low and during a 19lbs pass it ran outta mix and torched a piston(fixed it next day and on the lake following aftrnoon ).totally my fault.watermeth injection works awesome!! As long as ya check your tank level lmao i got lazy cuz it hardly uses any and jus didnt look it prior to the pass.i think a stock piston/rod smallblock(325ci) 105mph jetboat on 93 aint to shabby, im proud of it anyways
    i have a a.i.s. kit and my uncle has devils own.its the same nozzles and pumps in either kit but devils own is much cheaper, by 18-20%. i over spent for the a.i.s kit altho nice i cldve done it as nice and saved 120bucks.sorry rodneys attention isnt worth that to me.he way over estamated my nozzle sizes and i gave him all the specs.it took me using devil's own nozzle calculator on their site to fix it.devil's own has my vote and im runnin a a.i.s kit.
    if youre curious bout a nozzle size for your deal gn7 posted the link to devil's own water methanol injection site in a above thread.its pretty accurate.they sell complete 2 nozzle stage 1 kits with a gallon tank for about 260 shipped.nice stuff and the hobbs switxhes that come with stage 1 kit is way nicer than what comes with a.i.s.
    Member D Johnson's Avatar
    Jun 2013
    Yorba Linda/ Willow Valley
    Is this street or race? If race use good fuel and call it done. If street water/meth is a great application. I have an AEM, or Aquamist cannot remember which system, on my Tial twin turbo Porsche set it up to run off boost sensor and it works great controlling detonation up to a point. If really want to make power no replacement for good fuel but for running around on the street meth works awesome and can make surprising power on pump gas.
