blower cam
Results 1 to 8 of 8
blower cam
    Default blower cam
    I am in the middle of building a engine for my new boat and had a question on the cam I purchased a comp xs282s will it work with a 871 blower on a bbc. Originally it was going to be a tunnel ram motor but now I think I want to build a blower motor what do you guys think
    spokane, WA
    post all the spec's
    .Lift-int./exh.
    .Dur @ 50
    .Lobe speration
    .roller or flat tappet, solid or hydraulic
    What boost and rpm range are you looking for? What are your hp goals? Make and size of blower? Carbs?
    Take care,
    Travis
    comp xs282s 244/252 @.050" lift.598" flat mechanical 110 lobe/seperation
    I would like to get to around 650hp run about 6000rpm and 5-6 psi
    blower would be a hampton 671 or 871
    spokane, WA
    Looks good beside the lobe sep. A 112 at least would be best and a 114 even better but I would just insatll it and run it! It will be just fine!
    Good luck man.
    Travis
    Cantard 71hallett's Avatar
    snow bank
    What heads are you using?
    gen 6 large oval port
    snow bank
    If it makes you feel better my cam is a 110. My intake side was almost to good so I am letting some cylinder presure go. I thing you should just use it. On mine I cant get gready on the timing but it runs well.
    I think i am just going to go for it thanks for the input
