Head porting ???'s
Results 1 to 14 of 36
Head porting ???'s
    Bullhead city AZ
    Default Head porting ???'s
    I got a set of BBC 290's that were originally oval and now are rect port heads......... ( i bought them this way ) Now can i run a oval port intake or does it now have to be rect port ? Or just gasket match the ports on the intake to match..........
    Manwhore!!!!! Quick99's Avatar
    Fullerton, California, United States
    Sounds like you need a new set of heads. I would stick with a good set of 781,s or 049,s.
    Bullhead city AZ
    Quote Originally Posted by Quick99 View Post
    traded my 781's in on these heads and paid $800 for the new ones
    Please dont tell me that i need a new set of heads
    Lexington, KY
    Exclamation
    Quote Originally Posted by 468Bahner View Post
    Damn you change your mind too much!!!
    sounds like someone was shooting for more velocity on the runners.
    you can run a oval intake with rect port gaskets, it'll work, won't be right but it'll work and be sealed up.
    got any pics of the intake ports? there's not much meat there to be removing, hope they didn't get em thin.
    Bullhead city AZ
    Im supposed to pick em up here shortly if they ever get finished , so no pics as of yet
    El Cajon, CA.
    ... no pics as of yet
    Aren't there some pics of heads he's done the same thing to over on the SoCal forum?
    I don't know anything about porting, or why 468Bahner changes his mind so much , but the heads that I've seen the guy redo look extremely similar in port size to stock GM rectangle port heads.
    I'd say you need a vic jr. and an 800 dp holly.lol Sorry couldn't resist.
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    This is what my set of 290's had done.
    The even side had some detonation and is now pretty torched. Looking for a core...
ID:	17320   Click image for larger version.
ID:	17321   Click image for larger version.
    Yucaipa, Ca
    this begs the questionwhy?
    Well these were on the motor that came in the boat.
    My thinking would be that these are really small heads (101cc) and the more air and air velocity you can muster the better.
    The motor ran really well before the detonation issues.
    Bullhead city AZ
    As posted above the question is can i use a oval port intake , nothing about changing my mind And i dont change my mind that often
    i have some pics somewhere , i will post em up
    Bullhead city AZ
    Best i got for right now Jim/Rod sorry boys you wont be able to see anything Halfway down the page .......
    http://www.socaljetboats.com/index.php?topic=2830.250
    Quote Originally Posted by Constant840 View Post
    OUCH, did someone use a chisel and a hammer on those bad boys? Or did they break out something else.....
    As for 2Sav
    The oval intake will work just fine, it won't be "optimum" but it will seal and work good. Hope you're just planning to save for a rectangle intake and not thinking of changing those heads
