Minimum coil wire size
Results 1 to 2 of 2
    WV
    Default Minimum coil wire size
    Just doublechecking something , this may be silly question, but what is the smallest recommended coil wire size going from power supply to positive and negative on coil? Would this even matter?
    Denton, TX
    Well if no ones going to jump on this I will.
    Depending on the length of wire 14/12 will be fine.
    You're not putting a huge amount of voltage or current into the coil, all you need is 12 or 6 depending on who's coil it is. There’s tons’ coming out, but not going in. The negative side is for your tachs & triggers.
