help with idle speed question
    Member Rude Ron's Avatar
    Mar 2011
    Modesto
    Default help with idle speed question
    hello anyone know what at idle in gear rpm I should be running for twin 454 magnum engines with moderate 540 lift hydraulic flat tappet cams? I've keep it around a thousand rpm's cuz the motors are brand new so to make sure the cams are getting plenty of oil while idling out of the fairly long 5 mph no wake zone at the launch ramp, but thats too high and hard to dock, I'm confident the cams were broken in correctly on initial start up, but hear lots of horror stories about cam lobes going flat now days. I run a zinc replacement in my oil and have killer oil pressure with High Volume oil pumps, so what do you think a good in gear idle rpm is? thanks for any help ron
    here's a pic of the engines I just got em in the boat and have took it out about 4 times
    Quote Originally Posted by Rude Ron View Post
    If you have Bravo drives, I believe you need to be at 800 RPM or less to not hurt the drive when you put it in and out of gear.
    Apr 2010
    Rocklin, Calif.
    Hey, Hairball..What happend about the 2 drums of c-16?
    Randy
    ditto minus 200 rpm! In and out of gear at 1000 rpm will kill the out-drives. I would tune it and set idle at a max of 800 rpm! If you have break in time and the bottom end works well tune it down it a pinch. JMO!!!
