374ci 23* sbc+ 18 psi= 1216 horsepower
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 54
    okie, lake Texoma
    Default 374ci 23* sbc+ 18 psi= 1216 horsepower
    This little smallblock would make a hell of an engine for a jet. Check out the tq curve.
    http://www.yellowbullet.com/forum/sh...d.php?t=591269
    H8-2-W8
    [email protected] first pass
    Dec 2012
    More of them dam crutche's I LOVE IT
    1st, I am clling bullshit. 23* heads? No way. You have to have LS heads to make that kind of power. specially at that boost. Maybe 120 PSI of boost you could force that much air thru a set of 23* heads, but not 18.
    2nd, the cranks hanging by thread and ready to launch. Everybody knows you need at least 6 bolts to hold the crank in, and 4 of them MUST be horizontal.
    3rd, I could smell the N20 the second I opened the thread. Just another reason it needs at least 4 more bolts, and locating sleeves per main cap just to survive.
    okie, lake Texoma
    LMAO. You make sarcasm an art form.
    You forgot to add , "no way in hell with a carb, would HAVE to be EFI"
    H8-2-W8
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    i have seen (online, so it has to be the gospel) several turbo deals (not tooting Haas horn) make good tq numbers, dyno'd my ROOTS blown 468, at 11% over, peak tq was right at 880-900 and hp was 1100, my goal was to make over 1000 Hp, which i did so i was happy, but seeing these LS motor killing it and showing dependability and of course less weight..makes a feller start thing .....NAH! MY 60s TECH, BBC ROOTS DEAL, SOUNDS GOOD, LOOKS GOOD, AND DOES A DANG GOOD JOB!
    Aug 2009
    Maybe u should have had that small block when that flat bottom l cleaned your clock at lake Anna?roots blowers, 2carbs!
    Led
    Led is offline
    Jul 2010
    without GN i would probably rather stand on my head and gargle peanut butter...the Bobs keep the lights on...fyi..my first name is Robert...maybe thats why i like them
    okie, lake Texoma
    This wasnt an LS! It was an old school small block.
    H8-2-W8
    okie, lake Texoma
    Quote Originally Posted by twoblade View Post
    Dont worry hater, he knows how it would have went down if mine was still running at the finish line.
    H8-2-W8
    Senior Member bp298's Avatar
    LHC
    a poofer with a plastic intake manifold. that's perfect...
    LHC
    you didn't just play the shouldawouldacoulda card, didja????
    Led
    Led is offline
    Jul 2010
    sure looks like it...
    looks like an explanation of "the lake race" is needed, on the street you get ahead and hit your brake lights...on the water, if its close stay in, we have never really defined a finishing line...at the lake when i get ahead i pop the throttle and signal to the skier that we are headed back...rides over...lol
    You know better than that. Beer would use it as a sig line for the next 10 years.
    But I will say I call BS #4, because I bet it didn't have a mag and we both know that makes it impossible.
    that's the purpose built pressure relief that keeps the heads on. If you blow the manifold clean off and it lands in the water, it even floats. With the thermoset petro resins, the odds of your carb surviving the "poof" are greatly enhanced.
