blower spacers
Results 1 to 14 of 32
blower spacers
    Senior Member slotracer's Avatar
    Default blower spacers
    my top pulley is about 2" away from the mounting plate on the snout. whats the widest spacer that is safe to use? its on a 8-71 blower.
    spokane, WA
    How far do you need it to be out? Got a pic?
    not yet but i will take one later and post it
    Kingman/Golden Vly, Az
    Quote Originally Posted by slotracer View Post
    Hmmm...something seems to be amiss here!...i have 3 different blowers sitting in my shop & all my 8mm pullies fit just fine!...i dont ever re-call any pullies (1/2" or 8mm etc) haveing a different size hole in the middle?...they should all mount flush to the snout...if its too small, just hone it out til it fits!
    FastRat
    could be i need a longer snout.
    spokane, WA
    Thasts what I was thinking.
    Manwhore!!!!! Quick99's Avatar
    Fullerton, California, United States
    Will it hurt anything if you space it out? The blower shop sells spacers from a quarter inch to two inches. Just a solid spacer dont see how it would hurt anything.
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    never admit it
    Quote Originally Posted by Quick99 View Post
    this is what i am hoping to get away with. just wanting to know if anyone else has done it this way.
    Call the Blower shop and hear it from the Horses mouth. I am spacing my pulleys out and it looks pretty solid.
    Senior Member superdave013's Avatar
    I would think the bearings in the snout would not be as happy as they could be. You will be putting more leverge on them as you space the pulley out.
    I ran the short snout on my 8-71. You must be running a balancer and a pulley or 2.
    Also what intake are you using? Some of the older ones move the blower towards the mag.
    Quote Originally Posted by superdave013 View Post
    Not to jack the thread but i am running a B&M 420. THE KIT CAME WITH THE SINGLE PULLEY AND i NEEDED THE THREE V PULLEY FOR A MERC SET-UP.
    running a 8-71 on a weiland manifold. i have a crank hub, spacer single groove v-belt pulley then the blower belt pulley
    Those are the manifolds that move the blower back. I had to mill down the center of the bearing cap to clear a supermag. Life got better when I bucked up for a different intake.
