Blown 540 spark plugs?
Results 1 to 13 of 13
    Senior Member Smallblocksperry's Avatar
    Jul 2011
    Default Blown 540 spark plugs?
    can anyone recommend a good set of spark plugs to use
    just got my motor all done, minus having to pull it back out saturday for an oil driveshaft issue that should be resolved this weekend
    wondering how hot of a plug to run
    540 9-1 short block
    .650" solid roller .252/[email protected] 114
    brodix BB2 alum. heads
    7-10lbs of boost/intercooled
    pump gas
    locked out timing 31 degrees
    MSD 6m ignition
    26' cat with 1.36 gear swinging a 4 blade 30P prop
    also oil, i planed on running valvoline VR1 20-50, i used a moroso billet one piece built in pickup oil pump
ID:	347609   Click image for larger version.
Name:	blower motor.jpg
    Probably an NGK 8
    Feb 2009
    SF Bay Area
    The above is probably correct, my engine is very similar, runs NGK 9. A bit cold but no fouling at idle and the engine is run under boost for long periods of time, so I continue to use them.
    Quote Originally Posted by Smallblocksperry View Post
    540 9-1 short block
    pump gas
    MSD 6m ignition
    Uh oh...
    Quote Originally Posted by SFOcean View Post
    I would say 9's are good for extended periods of time like yours.
    I have a turbo engine currently running almost daily at Parker, made 1075 HP on pump gas on the dyno, he switched to 8's after initially running 9's, but I suggested he switch to a set of 9's if he enters a race with a fast skier.
    Member D Johnson's Avatar
    Jun 2013
    Yorba Linda/ Willow Valley
    Teague runs NGKR5671A-9 in my motors. I am changing them this weekend, last time they were changed was 2010 and only reason I am changing is I want to just because...
    Jul 2011
    Uh oh...
    Uh oh ? Care to elaborate...
    You said the "VR1" word...
    He could have said worse. At least he didn't add...'the best racing oil ever"
    Jul 2011
    whats wrong with VR1? what would you recommend?
    Nothing is wrong with it. So long as you understand it is a 5.00 a qt conventional oil and not some extreme oil that some try to make it to be.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    i have ran VR1 before, no its not the best, but it was on the shelf in the shop, i run brad penn now
    if you have it run it,
