gauge question
Results 1 to 7 of 7
gauge question
    Senior Member partycattin's Avatar
    Simi Valley,
    Default gauge question
    So my buddy was in my boat and noticed that when the ignition is off, all my gauges are pinned to the top.
    I checked 4 other boats that were with us and all of their gauges drop when the key is turned off.
    Is this normal for the needle/indicator to go up?
    If they seem accurate while it's running, I wouldn't sweat it.
    what brand of gauges do you have?
    Simi Valley,
    Not sure what brand.
    Advantage has the front custom done to include the "Advantage" logo.
    I can't see anything on the back to determine what brand they are.
    I know that I have an electrical problem between my dash and the main fuse panel. Just need to figure out what and where.
    I have the older red light up rocker switches on my dash for the blower, bilge, etc.
    The switches have been intermittent as far as lighting up when on. I noticed that if I turn them on/off a couple times they start to work and the volts on the gauge also jump up to about 13.
    I just put a new alternator in and I'm still having times that the gauge is only reading about 10-12 volts with none of the accessories on.
    I think that I may have a bad ground or something.
    member CONCEPT MARINE's Avatar
    Montclair, Ca.
    Default Gauges
    It sounds like you have a couple of problems. The gauges might be BEEDE. The needle has lay at some point when it does not have power, so that might be the case here. I would check the 12 pin engine connector (main plug) and also check all the ground connections. The switches, if they are the ones I think they are they just go bad.
    CUSTOMER & QUALITY SERVICE ARE NUMBER ONE
    Cantard 71hallett's Avatar
    snow bank
    Almost sounds like you are turning of the ground not the power.
    21' Daytona DaytonaTunnel's Avatar
    Enumclaw, WA
    95% of all electrical problems are a bad ground. A bad ground can do a number of wild things. Take the time to trace and clean EVERY ground. I'm sure you'll find a problem somewhere.
