carbs and boost
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
carbs and boost
    Senior Member Skydog's Avatar
    Jul 2010
    Default carbs and boost
    Hey guys with the meth all on going turn boost up 3-4psi,I am rich now when meth fires off. Buy going up in boost 3-4 does that lean the motor out much?
    Ty
    Turn it on at half your intended max boost level.i dont turn mine on till 8lbs which pumpgas 93 alone shld be good up till.runnin 50/50 mix up till 17lbs then i mix 60/40 above that.always turning on at 8lbs, i can see it briefly go alil fat but it blows past 8lbs so quik its hard to see.i can hear it start to inject sounds like a small shot of nitrous lighting off.yes the more boost you add past the turn on point will lean it out.ive been runnin 11.3 of the mix and when it comes on i see a dive to 10.8 and itll lean back to 11.3 by end of a 900ft pass.never ran straight meth thru it so dont have a clue what kinda afr drop id see there i imagine a full point or more richer.
    Jul 2010
    Awsome ty man!!!
    Jul 2010
    Thumbs up
    Its 600 with 8.200:1 compression, supper chiller, Dart pro heads, 260 intake at 50 and 268 exhaust at 50. 714 lift intake and 731 exahust 114 deg. It has a new Whipple 8.3 blower on her running 10PSI of boost at 800feet. Runing 91 fuel timming is locked at 32. Plugs are l Ngk 8s. What do you think safe is running meth 50/50. Was thinking 13-14psi would be 100% safe. Afrs around 11.5 Two 12 gph nozzles of meth.
    Thank u
    You 2 do realize you are comparing apples and oranges. One of you has an inny, the other an outie, I will let you decide who has what. But you cannot compare a blow thru car with a roots drawing thru carbs. Night and Day. The ying and the yang.
    Shydog, did you think you could throw a shit load of fuel into the deal with the meth and still maintain your AF? Where did you think the additional air for the additional fuel was going to come from?
    Jul 2010
    Yes I understand ty
    Member D Johnson's Avatar
    Jun 2013
    Yorba Linda/ Willow Valley
    Quote Originally Posted by Skydog View Post
    Thank u
    Awesome blower the 8.3, easy to make horsepower. That said, I would think you are pump gas safe to 10/11 pounds of boost. Run the meth off a boost controller and start introducing after 8/10 pounds and you should be able to run 13/14 pounds no problem. Question, why not just run Av Gas at 13/14 and call it done? I have 5 litre blowers on my motors, same as 8.3, running pump gas at 12 pounds of boost.
    Jul 2010
    Quote Originally Posted by D Johnson View Post
    Thank u what timming u at? What plugs?
    Jun 2013
    I do not know what timing Teague has mapped into his programming. Plugs Teague has me running NGKR5671A-9.
    Jul 2010
    Ty!!!
    Jul 2010
    Thumbs up
    Well put ngk 9s back in, smaller pulley. 10% to 20% and a touch bigger meth jets. Time to let her eat sat!
    Ty Skydog
    Jul 2010
    Thumbs up
    Wow I am happy guy now, she a freak now! :-) 13psi of boost wot afr 11.2-11.3 with the meth on :-) :-)!!
    Ty Skydog
    Thats awesome man on pumpgas! Im tryn to find some methanol so i can go to a 80% methanol 20% -20washerfluid mix and crank my boost up to 20lbs for laborday wknd id run straight methanol but i preturbo inject also and dont want straight methanol and air in my turbo.plus my bov vents below my charge pipe and it cld mist methanol towards hotside.
    Jul 2010
    Thumbs up
    Sweet man meth and turbos rock!!! I have a turbo sled that has a knock light. On pump 93 I can run like 12-13psi boost anymore I get small knock. With the meth on I can run her up to 25psi :-) :-)
