Headers?
Results 1 to 14 of 20
Headers?
    Surprise, AZ
    Default Headers?
    Currently I'm running Bassett twisties on my sbc 377 spinning it 5500. I run the headers dry since my cam is 106 lsa. I know the Bassett were designed with running wet taking into consideration the expansion of water into vapor . I assume the primaries on the headers are too big when running dry. I also assume this is hurting power? I was tossing the idea of having custom headers built considering, I will run them dry, any suggestions on primary size?
    Quote Originally Posted by 67weiman View Post
    You think Bassett accounted for the water/steam when they sized those headers?
    They use 2" pips for their wet and dry SBC headers, which is too big for 99% of the SBCs used in boats wet or dry.
    It depends on the built and the max RPM of the engine. Saying 377 means nothing if it spins 4500 Rs.
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    I always liked step headers on my small block motors.....1 3/4 to 1 7/8 x 3"......I'm sure others will give their input.....lots of smart folks around here.....
    Id rather live with a good question than a bad answer.
    Quote Originally Posted by Deweydaddy View Post
    I would say that's vastly better than the 2" that Bassett uses. I think the Bassetts are 99% bling factor of bigger tubes.
    I would say 1 3/4 X 1 7/8 or 1 5/8 X 1 3/4 step depending on the build.
    I like your thinking gn7....I just think.... for a small block....for what little bit of exhaust (piping) step style will help with scavenging and back pressure.....plz....by no means am I a expert!!!!! I like to read and listen to all you guys!!!!
    With Bassetts 2" primaries and 4" collector, you might as well saw the collector off and throw it in the lake
    I'd hate to waste those pieces......maybe make for some nice tips on a diesel power stroke exhaust.....
    I'd rather bolt the pair flange to flange, fill with them with rocks and sand and use them for anchors.
    Lol....you ain't right!!!....
    Close to the water...
    He justs needs to wind it to 9500 and leave it there
    Our headers are stepped several times
ID:	350490 Click image for larger version.
ID:	350498 Click image for larger version.
    Nice....
    Peoria, AZ
    I was really happy with what we put together. Nothing fancy. 1.75" OD primary 32" long (give or take) and a 3" OD collector. I can't remember what the collector length was. This was on a 327" sbc running right at 7000 RPM's with pump gas. Those were a touch on the big size if you ask me, but they still did a decent job, and were cheap to make.
    Paul
    You use those on a lake v drive and you are going to need the patented flame proof exhaust deflector or the driver is going to get torched!
Name:	jet boat exhaust.jpg
    Paul
    I think running at 7,000 rpm is key with that setup for sure.....sounds like a lil screamer....
