468 race spark plugs
Results 1 to 6 of 6
    Dec 2012
    Default 468 race spark plugs
    I am wondering what plugs you guys are running in your high compression motors, im running a ngk7 heres what i have its around 13to1 compression with brodix 2x heads, it seams a little cold for what i have its just all i could find at the parts houses around here.
    Atlanta, Texas, United States
    Quote Originally Posted by matt k wheeler View Post
    Most of the guys around here are running NGK 8's on the lake cruising and racing. On my race boat and cars with higher compression and high RPM drag racing, I run the NGK non-extended 9's. Have been for over 25 years. 7's or hotter and then 8's are cooler and then 9's even cooler. This info is correct if the engine is tuned correctly.
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    I ran the NGK 8's for a short while, after cruising around the lake for a couple of miles and skiing the boys if I tried to make a pass it was loaded up and would pop and spit and whimper for a bit, switched to the 7's and no problems. Ski and cruise for couple of hours and when I hammer it, she doesn't miss a beat ......Motor is a 13:1 w/Brodix BB 2X on a 532 BBC in my TR-2 ..... NGK (R5671A-7) 4091 work for me
    Apr 2010
    Rocklin, Calif.
    Im running 14.2 in a 498, and useing R5672A-9,lake deal TR, 2 750's..set the gap @ .35 with MSD..If your running A Mag..you might what to talk to the Dinosaur in Alaska..............
    Aug 2011
    Wasilla, Alaska
    Jealousy is ugly .... BTW it's spelled "using" (no e there stalker)
    031 RIVER4FUN's Avatar
    sparkplugs.com
    Anything you want and if you're in so cal usually get 'em the next day
