Paging GN7-Scoop and oil pan question
Results 1 to 11 of 11
    Member TOMSS1's Avatar
    Aug 2010
    Default Paging GN7-Scoop and oil pan question
    Bob - I am build a Blown gas 750hp BBC for my Hallett and trying to not break the bank. I have an old Olson scoop any problem using it vs the normal Dooley / Bassett style? I have an old kickout flywheel forward (which is how the boat is getting setup) Oil pan, Photos below, Good or Bad and if Good I assume I run a stud mounted tray with it? Thanks for all of your sage advise, Tom
ID:	353194   Click image for larger version.
ID:	353202   Click image for larger version.
    Olson scoop are fine. Kind of cool and different. As a forward facing scoop, I like it better than the Dooley/Basset. Backwards its pretty much makes no difference.
    Not a fan of the Dooley, specially in a flywheel forward, specially with the T sump.
    If you have it, put it on. Probably be fine for lake use. But I would keep my eye open for a Olson, or Armando
    You don't have much choice on the windage tray. It pretty much has to be a stud mounted tray with the flywheel forward Dooley
    The Dooley is not a "kickout" pan, it is a T sump pan. If you find a Olson or Armando 10 qt KICKOUT pan, it will control the oil much better than the Dooley. You don't need the extra 4 qt of the T sump, you need OIL CONTROL.
    Orlando.FL
    I use Armando pan and have no problem.
    looks like a few mods were made to the pan already. They should be helpful.
    S CP
    S CP
    GOOD EYE SLEEPER!!
    I didn't look at that pan that close, just read it was a Dooley.
    I don't think its modified, I don't think its a Dooley, uless its an OLD one. Dooley's have a waffle pattern bottom, and they use a stock type dip stick, not a screw in type.
    Like to see a side shot of that pan.
    Surprise, AZ
    Quote Originally Posted by gn7:2480666
    I don't see anywhere that the OP says it is a Dooley pan. ??
    Aug 2010
    Will do, I talked to Dooley and Craig thinks it is an old Milidon? I need a pick up and based on what I read their PUs are junk? Thanks Tom
    GOOD EYE SLEEPER!!
    Quote Originally Posted by 67weiman View Post
    You're right
    Quote Originally Posted by TOMSS1 View Post
    It is NOT a Milodon!!
    I would say its either a early Armando or a Aviad
    Lake Havasu az.
    Pan is same as my Milidon except for mine doesn't have side scraper, pickup is reinforced.....no windage tray and no oil pressure issues except for running in rough water that i shouldn't be running in anyway. I have Olson copy and i like it lots better than dooley shoe box...no air filters facing backwards....with the amount of water mine kicks up facing forward the motor might last a day. For some reason the pan used to push oil up dipstick tube...i run a rubber plug now.
    9 qts in the pan
    Sheriff Joe Arpaio
    Aug 2010
    Bob - Let me know what you think, Thanks for your help, Tom
    You're right
ID:	354514   Click image for larger version.
ID:	354522   Click image for larger version.
    Its not an Armando or Aviad.
    It might be a Milodon. I'd clean it up and run it,
