Forced induction: trying to decide between Whipple twin screw or Procharger.
Page 1 of 8 1 2 3 4 ... LastLast
Results 1 to 14 of 106
    Jul 2010
    Lubbock, TX
    Default Forced induction: trying to decide between Whipple twin screw or Procharger.
    So...I'm thinking about adding a blower to my 21' Liberator jet with an EFI 383 LS1. But, I can't decide between a Whipple or a Procharger (because I want a closed engine cover, turbos are not really an option right now).
    The target is 650-700 hp max. I will not exceed that with my current engine...and will most likely have the power down in the 600-625 hp range; but would like a little growing room.
    I had been set on a Procharger, and according to company I'd need 4-5 psi of boost with an intercooler to achieve my goal. But...then I did some thinking on the Whipple twin screw - and they appear to make good peak horsepower, but with increased power in the low to mid range over the Procharger. However, Whipple said my goal would require about 7 psi of boost. The Whipple is more money, BUT that prices includes the built in intercooler. However, once you add all the required parts to a Procharger, the price is very close to the same.
    I just have no idea which direction to go...so I'm looking for advice.
    "No, my boat doesn't need any more power" - No one ever
    okie, lake Texoma
    What are the service intervals on the different blowers? From what I understand the prochargers need rebuilt on a pretty regular basis. If the whipple setup will last a lot longer, is around the same money, and comes with the cooler, makes the decision kinda simple.
    H8-2-W8
    [email protected] first pass
    Member D Johnson's Avatar
    Jun 2013
    Yorba Linda/ Willow Valley
    Whipple will definitely make more power in the low/ mid range. Prochargers are making tons of power top end for sure. I have 5 litre Whipples on my boat and the service interval on Whipple is change the gear oil in front once a year and that is it. The twin screw rotors do not come in contact with each other so require no maintenance. This is one of the benefits of the Whipple design and in turn they produce very low discharge temperatures. I would imagine that a 2.3 Whipple would support your horsepower goals, maybe a 3.3 if you wanted to make more HP later. Call Whipple they will give you good advice.
    Tower Park Resort, Lodi, CA
    If you're gonna stay with a jet, the low range benefits of the Whipple will go mostly unnoticed, my vote would go toward the ProCharger. If an out-drive is still on the table of future possibilities, the Whipple should make a notable difference in acceleration.
    Jul 2010
    Lubbock, TX
    The outdrive is looking less like a possibility.
    A couple weeks ago I had the opportunity to see how my boat ran in comparison to a powerful outdrive and 300xs powered outboard. I just don't think I can live without my acceleration. Apparently top speed isn't everything.
    The pros to the twin screw is that it's an "all-in-one" unit and the install would be super easy. I'm still unsure if they make the same peak power as a centrifugal (assuming similar size and boost). The less boost I can run, the happier I'll be. Just not sure what I need here.
    I have a Procharger
    Go with the whipple
    #55
    I have a Procharger
    Go with the whipple
    Wow, that says a whole bunch there!
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Quote Originally Posted by formulazr View Post
    the outdrive is looking less like a possibility.
    A couple weeks ago i had the opportunity to see how my boat ran in comparison to a powerful outdrive and 300xs powered outboard. I just don't think i can live without my acceleration. Apparently top speed isn't everything.
    The pros to the twin screw is that it's an "all-in-one" unit and the install would be super easy. I'm still unsure if they make the same peak power as a centrifugal (assuming similar size and boost). the less boost i can run, the happier i'll be. Just not sure what i need here.
    I wonder where I have heard that before. If you are like most boaters that I know you will want way more boost that what you start with...
    Steve
    JMO but I think the Whipple will be easier on the crank snout.
    Not as much of issue with a BBC at low boost, but on a LS it might be something to consider, even at low boost.
    Jul 2010
    Lubbock, TX
    I have a Procharger
    Go with the whipple
    Why? What about the Procharger are you not happy with?
    Quote Originally Posted by Roaddogg 4040 View Post
    Steve
    Well...touche - but in this case it mostly true. I just don't think this engine can exceed 700 hp reliably.
    Pardon my ignorance, but what would make the Whipple easier on the snout than a Procharger?
    GN7 - snout aside, if you were shooting for power above 5000 rpm, do you think the Whipple or Procharger would be better suited for that? What I've read indicates that the twin screw makes good power in high rpms, but I've never dealt with one personally to know. I do know I told Whipple and Procharger both to figure an engine with 450 hp baseline (figured dropping my cam size and compression will knock me from 525-550 to 450-500, and wanted to figure on the low side). Procharger said 4 psi would get me around 650 hp and Whipple said 7 psi would get me around 650 hp. I'm not real FI savvy...so I don't know why the difference IF the twin screw is as efficient as I'm led to believe.
    Plus...the guy I got on the phone at Whipple wasn't real excited to be talking to me...so maybe getting someone more helpful would be beneficial. When I told him I had an LSx engine, he told me to call Mast for help/advice.
    Jan 2013
    Magic Mountain CA
    I have a M-3SC Procharger with intercooler that I bought in 2007. Has been on 2 boats now. Change the oil once a season. Works great no maintenance issues. I have lots of bottom end, mid range and top end. Bottom line when I hit the throttle it takes off hard. Roughly 10 mph to 94 mph in 5 seconds or so. When it was on my 21' Eliminator it was an all around increase in power and everything fit under the engine hatch.
    Formula ZR
    PM me if you want to talk about it. I've gone through the process learning as I go and now have 6 years. I ran 5 psi for quite a while when I bought it, now I'm up to 9 psi due to engine changes that can handle the boost.
    Intercooler is more efficient with the Procharger which is why you get a little more HP with less boost.
    I need to take some more pics, I've done a few upgrades, Imco fuel tank for one.
    Jan 2013
    Magic Mountain CA
    When the time comes I got a price of $350 for a complete rebuild from Procharger. This is assuming nothing major has gone wrong. After 6 years I still don't know when I'll need to send it in.
    Jul 2010
    Lubbock, TX
    ^^ Understood on the intercooler...but the Whipple has an intercooler also. Maybe it's not as efficient? Or???
    New here Beer:30's Avatar
    Bakersfield, CA
    I didn't follow your build, so what intake do you have on it? Factory plastic or a metal FAST or other?
    If you went Whipple, how would you configure the EFI? With the ProCharger or (eventually) turbo(s), as long as you have a metal intake, you can stick with that and just blow into the existing setup.
    With the ProCharger, you could just run a 3-5 psi non-intercooled setup (to save $) and then always add IC later for more boost. More of a "modular" setup than an intake-mounted SC.
