problem with motor in jet boat
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 117
    Senior Member MR.Magoo's Avatar
    Default problem with motor in jet boat
    okay boat motor started running like crap, then it got really hard to start, then it wouldn't start. motor is a IV bbc 468, 10.5 -1 tunnel ram two 750 dp, 590 lift cam, msd dizzy with 6al box, I have a spare box and distributor cap , and I figured out that one of my 6al's were bad, so now the boat fires up , but immediately dies, fuel bowls are full cause I can see the sight glasses I have enough fuel pressure, and have spark at each plug, any clue what it may be? I checked the ground from the battery and actually moved it from the engine rail to the engine, the msd box is grounded to the battery also, any clue? sure would like to put it in the water.
    Senior Member Skydog's Avatar
    Jul 2010
    Check compression man
    Apr 2010
    Rocklin, Calif.
    Is the dist. moving?....how is the timing chain?..did you remove Balest Resistors?
    Lake Havasu az.
    You moved the ground for the battery......Is it cranking over properly? Or is it hard to start and runs poorly when it does?
    Sheriff Joe Arpaio
    did compression check all cylinders 150, distributor is moving, I had the cap off and put it to tdc to remove the dizzy to check with my spare if the dizzy was messed up,never have run ballast resistors,not sure on timing chain guess I can pull balancer off and open up and check, I removed the ground, starter is new and seems to turn over like usual, like I said it will start for about 5 seconds then die, and then I can walk over to carbs and pump it once and it start, and then die again, and pumping the throttle doesn't help it still dies., do you think my other msd is bad?
    Jul 2010
    Get a timming light on it and watch what its doing.
    okay I will tomorrow, and get back with ya'll its late over here in texas,
    Without a boat hondoboat's Avatar
    Nor Cal
    Ignition switch bad?
    Quote Originally Posted by MR.Magoo View Post
    If you have a stock ignition set-up install it and recheck before you start pulling the engine apart!!!! No offense but I would work from the easy checks down! M
    Close to the water...
    Quote Originally Posted by hondoboat View Post
    Good point !
    Seen that movie before
    If you start this thing by turning a key that pops back to run position after it starts, like ol guy and Steve said, CHECK THE SWITCH.
    If you just turn a key and push a button, or flip a switch and push a button, I doubt its the switch. If it has power when it started, the toggle switch should have power even after it starts.
    But a regular key switch, like a car, its probably the switch.
    If you already lost a MSD box, that switch probably killed it when it started running like shit. Turning off and on with every little bump. They don't like that at all.
    Senior Member k555's Avatar
    Mar 2010
    I've had this happen along time ago in a old boat I owned. Key switch is bad.
    Thanks guys
    Apr 2010
    Rocklin, Calif.
    Know that I think about...a buddy of mine had a similar issue, runnig Msd...start-die..start-die, well come to find out it had a Mag Tach in it
